You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (231) English
Posted by: pspad | Date: 2017-05-24 18:58 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (227)
PSPad x64 Hexeditor - access violation in some cases
Duplicate line function
Edited 1 time(s). Last edit at 2017-05-25 06:24 by pspad.
Posted by: crimson | Date: 2017-05-25 05:20 | IP: IP Logged
Thanks for fixing duplicate line function.
Posted by: Macari | Date: 2017-05-25 14:34 | IP: IP Logged
Good work!
I found this one: Characters like ↪ not working in pspad. Is this a bug? Format is set utf8. I see only a rectangle. In Microsoft Notepad its working fine.
Edited 1 time(s). Last edit at 2017-05-25 14:34 by Macari.
Posted by: pspad | Date: 2017-05-25 16:54 | IP: IP Logged
It depends of used font. Set same font in Notepad as you use in PSPad.
Posted by: Macari | Date: 2017-05-26 11:16 | IP: IP Logged
It is. I use in both "Consolas" with same font-size.
See www2.pic-upload.de
Posted by: PGomersall | Date: 2017-05-26 22:14 | IP: IP Logged
Jan, getting an access violation on odd occasions I close a file by middle clicking the tab. This is usually the last tab open but it does not always occur. This locks PSPad completely and there is no access to the error dialog to send it back to you. The only way to exit is to kill PSPad. This is with the x64 version. Next time I will take a screen shot if that is useful. I will send more details if a pattern becomes apparent.
Keep up the good work.
Pete
Posted by: starfort_jp | Date: 2017-05-27 06:19 | IP: IP Logged
Thank you for the update.
I noticed that the star on encoding setting is fixed and unchangeable(always ANSI default.) How can I change the character encoding on 5.0.0?
Posted by: pspad | Date: 2017-05-27 06:38 | IP: IP Logged
starfort_jp:Hello,
Thank you for the update.I noticed that the star on encoding setting is fixed and unchangeable(always ANSI default.) How can I change the character encoding on 5.0.0?
Ctrl+click in the encoding menu oe default encoding in the program settings / files
Posted by: starfort_jp | Date: 2017-05-27 07:01 | IP: IP Logged
I confirmed it.
Thank you very much.
