You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (211) English
#1 PSPad unicode 5.0.0 (211) English
Posted by: pspad | Date: 2017-05-17 05:36 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (203)
Hex editor search
Multiline File tabs with maximize and restore
Paste as HTML
Find in Files - fill selected text into search field
File tab icons after file close
C++ Code explorer and functions
Vertical line on cursor position - wrong position on file with real tabs
#2 Re: PSPad unicode 5.0.0 (211) English
Posted by: Andreas | Date: 2017-05-17 13:18 | IP: IP Logged
Hi Jan,
again I lost my PSPad.INI after copying new files from 211 into installation folder.
I made a backup within settings. Within that backuped zip file all ini files have a lowercase prefix.
Could it be that pspad did not recognize this restored lowercase ini files? I also found a PSPad.INI and Recent.INI in C:\Users\Andreas\AppData\Roaming\PSpad. Could it be, that pspad fetches the ini from this folder? I'm on a portable version and not in multiuser mode.
BTW It's unusual to use uppercase file suffix.
Regards Andreas
#3 Re: PSPad unicode 5.0.0 (211) English
Posted by: PGomersall | Date: 2017-05-17 14:10 | IP: IP Logged
Jan, The exception caused by closing tab by middle click seems to be fixed in x86 and x64 with 211.
#4 Re: PSPad unicode 5.0.0 (211) English
Posted by: Shores | Date: 2017-05-17 14:46 | IP: IP Logged
64bit version crashes while closing the last file by clicking on the X in the file tab
Exception description:
List index out of bounds (-1).
Exception class:
Exception address:
Stack list, generated 17/05/2017 16:44:04
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (211)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 3839,
Processor: AMD, AMD FX(tm)-6300 Six-Core Processor , 4100 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2017-05-18 14:31 by Stefan.
#5 Re: PSPad unicode 5.0.0 (211) English
Posted by: Shores | Date: 2017-05-17 15:07 | IP: IP Logged
This happens also in 32bit version...
#6 Re: PSPad unicode 5.0.0 (211) English
Posted by: Bobf | Date: 2017-05-18 13:08 | IP: IP Logged
as a workround, open a new empty document, and close all other tabs, and the new empty tab at last,PsPad will not get the exception crash.
#Bobf
#7 Re: PSPad unicode 5.0.0 (211) English
Posted by: pspad | Date: 2017-05-18 13:13 | IP: IP Logged
Wait until this weekend.
