You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (207) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.0 (207) English
Posted by: pspad | Date: 05/14/2017 15:14 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.0 (203)
Hex editor search
Multiline File tabs with maximize and restore
Paste as HTML
Find in Files - fill selected text into search field
File tab icons after file close
#2 Re: PSPad unicode 5.0.0 (207) English
Posted by: AndreasW | Date: 05/15/2017 08:15 | IP: IP Logged
Is there no 64-bit version?
#3 Re: PSPad unicode 5.0.0 (207) English
Posted by: pspad | Date: 05/15/2017 08:18 | IP: IP Logged
I had no time to fix reported problems in 64b version so I didn't included it.
I hope next time
#4 Re: PSPad unicode 5.0.0 (207) English
Posted by: MadCompie | Date: 05/15/2017 10:48 | IP: IP Logged
sandrosilveira:
MadCompie:
srce:
It looks like the red marker in the file tabs that indicates if a file has unsaved changes no longer works correctly. Sometimes when closing files, the marker appears on files that have no changes. When selecting that file, the marker then disappears. It's not obvious how to reproduce it, but I believe I've seen it a few times.
I also encoutered this... very often the red marker appears in the first tab (always?) while the source was not modified... I also tried to remember why/when but did not find the cause yet...
Hi Jan,
To simulate this (5.0.0 203):
- Open 5 files
- Modify something in the 5th file
- Click the 2nd file tab
- Close file using CTRL+F4
The red marker are show incorrectly in 2nd tab...
Sandro
Thx Sandro, I can now simulate this too with this build 207:
- open some (5?) files
- modify the 2nd file
- click the last file tab
- close this last file tab
the red marker appears now in my first tab...
Edited 1 time(s). Last edit at 05/15/2017 10:49 by MadCompie.
#5 Re: PSPad unicode 5.0.0 (207) English
Posted by: pspad | Date: 05/15/2017 11:29 | IP: IP Logged
Thank you for report.
I hope I finally found it.
#6 Re: PSPad unicode 5.0.0 (207) English
Posted by: pspad | Date: 05/15/2017 12:06 | IP: IP Logged
srce:
Hi. Text Diff with File doesn't seem to work properly in the 64-bit version. The highlighting is wrong. Looks ok in the 32-bit version though. Thanks.
Hello srce.
I tested it, but I didn't see any problem. Can you send me example what causes wrong text diff highlighting in x64 version?
Edited 1 time(s). Last edit at 05/15/2017 12:06 by pspad.
#7 Re: PSPad unicode 5.0.0 (207) English
Posted by: programmer9 | Date: 05/15/2017 21:21 | IP: IP Logged
Thank you for fixing the find in files selected text problem.
#8 Re: PSPad unicode 5.0.0 (207) English
Posted by: crimson | Date: 05/16/2017 13:58 | IP: IP Logged
I can see the C code explorer issue fixed in this version. Thanks for your great support.
However, I don't see the history for this change.
Best regards.
#9 Re: PSPad unicode 5.0.0 (207) English
Posted by: pspad | Date: 05/16/2017 14:37 | IP: IP Logged
crimson:
Best regards.
You are right. Sometimes, when I do several things at once I forget to write the change log.
#10 Re: PSPad unicode 5.0.0 (207) English
Posted by: PGomersall | Date: 05/16/2017 19:41 | IP: IP Logged
Jan, middle clicking mouse button on tab causes exception. Going back to 204 fixes it.
Edited 1 time(s). Last edit at 05/16/2017 19:45 by PGomersall.
Goto Page: 1 2 Next
