You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (191) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-05 15:31 | IP: IP Logged
Here is fixed Syntax file for TEXI
Quote:
[Settings]
Name=Texinfo
HTMLGroup=0
Vectors=0
Label=0
FileType=*.texi
CommentString=
TexInfoComment=1
IndentChar=
UnIndentChar=
TabWidth=0
CaseSensitive=1
DoubleQuote=1
EscString=0
EscChar=\
KeyWordChars=@
CodeExplorer=ftUnknown
DocComment=
[KeyWords]
@acronym=
@b=
@c=
@cite=
@code=
@command=
@dfn=
@email=
@emph=
@env=
@file=
@i=
@kbd=
@key=
@option=
@r=
@samp=
@sc=
@strong=
@t=
@url=
@var=
[ReservedWords]
@appendix=
@appendixsec=
@appendixsection=
@appendixsubsec=
@appendixsubsubsec=
@author=
@bye=
@center=
@centerchap=
@contents=
@detailmenu=
@end=
@exampleindent=
@group=
@heading=
@headings=
@chapheading=
@chapter=
@lowersections=
@majorheading=
@page=
@paragraphindent=
@printindex=
@raisesections=
@section=
@setcontentsaftertitlepage=
@setfilename=
@setchapternewpage=
@setshortcontentsaftertitlepage=
@settitle=
@shortcontents=
@shorttitlepage=
@subheading=
@subsection=
@subsubheading=
@subsubsection=
@subtitle=
@summarycontents=
@title=
@titlefont=
@titlepage=
@unnumbered=
@unnumberedsec=
@unnumberedsubsec=
@unnumberedsubsubsec=
@vskip=
\\input=
[KeyWords2]
@anchor=
@asis=
@cartouche=
@cindex=
@columnfractions=
@display=
@enumerate=
@example=
@exdent=
@findex=
@flushleft=
@flushright=
@format=
@ftable=
@inforef=
@item=
@itemize=
@itemx=
@kindex=
@lisp=
@menu=
@multitable=
@node=
@noindent=
@pindex=
@pxref=
@quotation=
@ref=
@smallbook=
@smalldisplay=
@smallexample=
@smallformat=
@smalllisp=
@syncodeindex=
@synindex=
@tab=
@table=
@tindex=
@top=
@uref=
@vindex=
@vtable=
@xref=
[KeyWords3]
PSPad hangs in case when @ isn't included in Keyword chars field. I must find a reason and fix it. This highlighter works. I added about 2 keywords from your license file
#22 Re: PSPad unicode 5.0.0 (191) English
Posted by: human | Date: 2017-05-08 06:37 | IP: IP Logged
Thanks for the feedback and the extended syntax file (I guess it is shipped with the next full install). It is good that you found a way to reproduce the bug.
I suppose after the fix the highlighter will just not work when the @ is removed - but I wonder in general why this field exists, shouldn't the "allowed chars in keywords" be derived from the keywords actual in the syntax file?
Can I do something for ftTexinfo or is this completely up to you?
#23 Re: PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-08 07:54 | IP: IP Logged
It's fixed in the yesterday build.
Use syntax file content I provided in add abbove
#24 Re: PSPad unicode 5.0.0 (191) English
Posted by: human | Date: 2017-05-08 08:29 | IP: IP Logged
using build 203 it even works without the "@" in "KeyWordChars=".
Thank you for the fix and "speed up in Code Explorer" sounds good in general.
Question: Is the field KeyWordChars still needed or can it be dropped completely, with the "allowed chars in keywords" being derived from the keywords actual in the syntax file?
Second question: Can I somehow add a code explorer for this or do you have to code a ftTexinfo?
#25 Re: PSPad unicode 5.0.0 (191) English
Posted by: pspad | Date: 2017-05-08 08:53 | IP: IP Logged
Let the @ char in keywords char, cause it's really part of keywords.
Code explorer isn't user definable.
I need to know what should be code explorer content and I will add it
#26 Re: PSPad unicode 5.0.0 (191) English
Posted by: human | Date: 2017-05-08 09:52 | IP: IP Logged
Question: Is the field KeyWordChars still needed in general in PSPad or can it be dropped completely from the application, with the "allowed chars in keywords" being derived from the keywords actual in the syntax file instead? (Note: Texinfo currently needs the @, otherwise keywords within the text aren't highlighted).
Hierarchical nodes in Texinfo (that I'm aware of):
[@part ->] [@chapter ->] [@section | @unnumberedsec ->] [@subsection]
[@part ->] [@appendix ->] [@section | @unnumberedsec | @appendixsec | @appendixsection ->] [@subsection]
No need to distinguish between both variants via single "main" nodes.
And ideally another node for the includes: @include | @verbatimcinlude
See www.gnu.org for the details
Edited 1 time(s). Last edit at 2017-05-08 09:53 by human.
