You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (187) English
Posted by: Stefan | Date: 2017-04-26 13:40 | IP: IP Logged
Danke.
I will wait for the "Sort > Reverse string" fix to see what that does
and send than the Deutsch_5_187.ini to Jan.
Posted by: Macari | Date: 2017-04-26 16:50 | IP: IP Logged
pspad 187 have strange behavior
1. open blank tab
2. press more than 3 times tab
3. write 'xxx' => '
4. after this insert from clibboard a text
result
text from clibboard is insert with many spaces after it. see caret.
Posted by: Andreas | Date: 2017-04-26 17:43 | IP: IP Logged
I cannot confirm this. Tested with all these two settings in editor properties regarding the line end.
Posted by: Macari | Date: 2017-04-26 18:53 | IP: IP Logged
Fine for you, but the issue exists. I have fresh installed latest 4.x and updated with version 5 (187). I found maybe the problem coming with this red marked setting: www2.pic-upload.de
1. start pspad
2. press tab tab tab tab
3. type few characters
4. insert from clibboard text
result like writing above... many unwanted spaces after inserted text.
Posted by: Andreas | Date: 2017-04-26 22:09 | IP: IP Logged
No, sorry cannot reproduce it even with this setting.
Maybe you have to post your complete PSPad.INI.
My statusbar shows UNIX, Unicode UTF-8 no BOM. Font ist Consolas 11.
Posted by: Macari | Date: 2017-04-27 10:45 | IP: IP Logged
Here another bug in a blank tab
1. press tab tab tab tab
2. type few chracters and select all characters
3. paste text from clipboard
result:
tabs before selected text are removed/shrinked?
Edited 1 time(s). Last edit at 2017-04-27 10:45 by Macari.
Posted by: AndreasW | Date: 2017-04-28 13:12 | IP: IP Logged
How about a 64-bit version of PSPad 5.0.0? It would be really cool if PSPad could open large log files.
Posted by: pspad | Date: 2017-04-28 13:16 | IP: IP Logged
AndreasW:How about a 64-bit version of PSPad 5.0.0? It would be really cool if PSPad could open large log files.
I have 64b version, but still without scripting support.
Posted by: AndreasW | Date: 2017-04-28 13:57 | IP: IP Logged
pspad:I have 64b version, but still without scripting support.
Could you please publish it? I don't care about scripting support.
Posted by: pspad | Date: 2017-04-28 14:30 | IP: IP Logged
OK. When I will publish next build, I will add 64b version
