You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (187) English
Posted by: AndreasW | Date: 2017-04-28 16:01 | IP: IP Logged
pspad:OK. When I will publish next build, I will add 64b version
Great! Thank you.
Posted by: pspad | Date: 2017-05-02 12:36 | IP: IP Logged
Macari:Here another bug in a blank tab1. press tab tab tab tab
2. type few chracters and select all characters
3. paste text from clipboardresult:
tabs before selected text are removed/shrinked?
Check program settings / Editor1 - trim trailing spaces option
Posted by: Andreas | Date: 2017-05-04 21:48 | IP: IP Logged
I closed my portable pspad which runs in a folder with all rights. Then I opened it again and have a complete new PSPad.INI. All my settings are lost.
Windows 10 64bit.
I was able to recover a backuped INI from 30.10.2016.
I searched a bit and found another INI in C:\Users\Andreas\AppData\Roaming\PSpad\ from 25.02.2017 which also has not my settings. (today is 04.05.2017)
Multiuser mode is not set.
Now I set the INI to readonly and precautionary made a backup of the INI.
How can this happen? This is real bad.
Regards
Posted by: pspad | Date: 2017-05-05 04:49 | IP: IP Logged
Andreas:I closed my portable pspad which runs in a folder with all rights. Then I opened it again and have a complete new PSPad.INI. All my settings are lost.
You are right, it's bad. It happened in some past build. I though it was fixed.
I will try to check it.
Posted by: pspad | Date: 2017-05-11 09:33 | IP: IP Logged
crimson:Hi,
I still can see the Code Explorer Windows shows incorrect result in C/C++. See below code piece for instance./**
test
VOID
FuncA (
IN AAA *aaa
if (AAAA) {
BBBB;
FuncB (
CCCC
);if (DDDD) {
EEEE;
FuncB (
CCCC
);if (FFFF) {
GGGG;
FuncB (
CCC
}The result in Code Explorer Windows is:
FuncA (
FuncB (
FuncB (
FuncB (The expectation should be only FuncA (
Please help to check this. Let me know if you need more information.
I hope it is fixed. Check next build
