You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (176) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-04-10 12:14 | IP: IP Logged
sandrosilveira:
Hi Jan,
I have 14 programmers working with 5.0.0 and really is very stable, the exceptions have not happened for more than a week. The only thing that they are missing is the compilation in separated threadforum.pspad.com, please, if possible priorize this, then I can liberate for more programmers to use this new version.
Thanks for your great job!!
Sandro.
It should be part of this version. I though that I forgot something in changes. Check it please.
#12 Re: PSPad unicode 5.0.0 (176) English
Posted by: sandrosilveira | Date: 2017-04-10 14:08 | IP: IP Logged
sandrosilveira:
Hi Jan,
Sandro.
Jan,
I have tested now with 5.0.0 (176) and still doesn't working, PSPAD freezes until the end of compilation.
Sandro
#13 Re: PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-04-10 14:48 | IP: IP Logged
sandrosilveira:
Jan,
Sandro
It works in case catch compiler output is checked.
Compiler is running in separate thread, it shouldn't block PSPad. I will check it.
#14 Re: PSPad unicode 5.0.0 (176) English
Posted by: human | Date: 2017-04-10 14:53 | IP: IP Logged
Menu entry Projects->Sabe Project As... is disabled after loading a project file. Looks like a bug.
#15 Re: PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-04-10 14:55 | IP: IP Logged
human:
I can't confirm. Save project ans Save project as is disabled for empty project - it has no sense to save empty project.
#16 Re: PSPad unicode 5.0.0 (176) English
Posted by: human | Date: 2017-04-10 15:04 | IP: IP Logged
human:
Menu entry Projects->Save Project As... is disabled after loading a project file. Looks like a bug.
Yes, it doesn't make sense to save an empty project, but the project isn't empty.
Retesting:
* close PSPad
* open PSPad --> last project is open, Projects->Save Project As... is available
* open another project via Projects (one of the history ones)
--> project is open, Projects->Save Project As... is *not* available any more
#17 Re: PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-04-10 15:08 | IP: IP Logged
human:
Retesting:
* close PSPad
I found problem. It's disabled in case no file is open, right?
It's a bug
#18 Re: PSPad unicode 5.0.0 (176) English
Posted by: human | Date: 2017-04-10 16:03 | IP: IP Logged
It's a bug
I'm not at the PC for testing now, but I'm quite sure that no file was open when I've tested this. Another bug fixed smiling smiley
#19 Re: PSPad unicode 5.0.0 (176) English
Posted by: Shores | Date: 2017-04-13 10:02 | IP: IP Logged
Sorry to bother, but the Code Explorer is behaving strangely in this version...
If the method is like that:
public function __wakeup() {
parent::__wakeup();
Then the other methods that follow are shown as childs of __wakeup() method as you can see in the image...
Sorry, forgot to mention that I'm speaking of PHP classes!
Edited 3 time(s). Last edit at 2017-04-13 10:08 by Shores.
#20 Re: PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-08-10 11:19 | IP: IP Logged
Shores:
parent::__wakeup();
If there is an open bracket { without close bracket, another methods are inside.
Please send me more complex code sample
