You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (176) English
Posted by: pspad | Date: 2017-04-09 18:43 | IP: IP Logged
Download links (5.2 MB):
Changes to 5.0.0 (174)
News
TeX family - added multiline comment support \bC ... \eC
Problem of highlighter specification tab content loading (doc comments e.t.c.)
Submenu items size on high DPI
Posted by: Stefan | Date: 2017-04-09 20:12 | IP: IP Logged
Someone has been busy today
Thanks for permanently deployment. U R marvellous.
Posted by: pspad | Date: 2017-04-10 05:06 | IP: IP Logged
I think version 5 is ready to be published.
Number of exceptions was significantly decreased (include comparing to version 4)
Now I need to make functional scripting in 64b version, cause it's the only thing.
Posted by: human | Date: 2017-04-10 06:55 | IP: IP Logged
PSPad help seems to be kind of a modal window.
* open PSPad
* open help with [F1] and use it --> works
* switch back to PSPad with [ALT]+[TAB] (don't close the help)
* open program settings
* switch back to PSPad help (don't close the settings) --> cannot be used at all
* even re-opening help with [F1] in program settings doesn't lead to a "working" window (the help entry is updated correct but the window is unusable, even "close" or "minimize" won't work)
Posted by: pspad | Date: 2017-04-10 08:16 | IP: IP Logged
Help is external application, controlled by MS Help application. I can start it with initiate topic only.
Posted by: tmtisfree | Date: 2017-04-10 08:25 | IP: IP Logged
Hi Jan,
I only got 1 exception when working not remotely the entire last week, not too bad when compared with version 4.
I have began to work again remotely (RDP) since last saturday, and I got 2 ou 3 exceptions (when pasting code) so far, but no corruption yet.
I will keep you posted if the corruption reappears.
Initial loading time of PSPad is now good, only closing the program is slow.
Best,
TMTisFree
Edited 1 time(s). Last edit at 2017-04-10 08:26 by tmtisfree.
Posted by: human | Date: 2017-04-10 09:30 | IP: IP Logged
pspad:Help is external application, controlled by MS Help application. I can start it with initiate topic only.
How do you start the external application? I bet it goes away if you start the application not attached to the main executable which has only one side effect: closing PSPad doesn't close the help any more, but I'd say this is better (and maybe even wanted if the help has a "restart PSPad" in somewhere) than the help application blocked by the application it is about.
Posted by: human | Date: 2017-04-10 11:10 | IP: IP Logged
"Project information" looks very strange (the headlines seem to be written multiple times) on Win10, normal DPI, no size/font/DPI change in PSPad or Windows. Can you reproduce this or should I try to find an online-upload?
Posted by: pspad | Date: 2017-04-10 11:21 | IP: IP Logged
human:"Project information" looks very strange (the headlines seem to be written multiple times) on Win10, normal DPI, no size/font/DPI change in PSPad or Windows. Can you reproduce this or should I try to find an online-upload?
Confirmed. I guess it's a first time anybody run this form in PSPad 5. I will fix it
Posted by: sandrosilveira | Date: 2017-04-10 11:54 | IP: IP Logged
pspad:I think version 5 is ready to be published.
Number of exceptions was significantly decreased (include comparing to version 4)Now I need to make functional scripting in 64b version, cause it's the only thing.
Hi Jan,
I have 14 programmers working with 5.0.0 and really is very stable, the exceptions have not happened for more than a week. The only thing that they are missing is the compilation in separated threadforum.pspad.com, please, if possible priorize this, then I can liberate for more programmers to use this new version.
Thanks for your great job!!
Sandro.
