You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (174) English
#1 PSPad unicode 5.0.0 (174) English
Posted by: pspad | Date: 04/05/2017 12:36 | IP: IP Logged
Download links (5.2 MB):
Changes to 5.0.0 (171)
News
ASCII chart - Print function uses HTML page now
File info dialog - grids column width is sized by window width. Dialog size is remembered during PSPad session
Sort dialog - added revers string sort functinality
Code explorer parse files in thread, it means faster program start
C++ Code explorer includes wrong code into functions list
SQL code parser - comments are removed before parsing
#2 Re: PSPad unicode 5.0.0 (174) English
Posted by: PGomersall | Date: 04/05/2017 16:02 | IP: IP Logged
Jan,
Since you are obviously spending a lot of time on developing PSPad at the moment, do you intend to fix the taskbar icon placement issue and tray icon?
1) Icon appears on default taskbar even when PSPad window on another monitor
2) Tray icon is old image now new
#3 Re: PSPad unicode 5.0.0 (174) English
Posted by: pspad | Date: 04/05/2017 16:38 | IP: IP Logged
1. How to configure multimonitor?
2. It's not a old icons. I wanted to make difference between old and developer builds of new PSPad. Full release will get back blue icon.
In the future I will probably use gray icon for developer builds and blue one for full releases.
#4 Re: PSPad unicode 5.0.0 (174) English
Posted by: PGomersall | Date: 04/05/2017 17:01 | IP: IP Logged
Jan,
1) Taskbar where window is open. However, I do have PSPad pinned to TaskBar. While PSPad in active and window open icon is only showing on primary monitor. If I minimize PSPad, icon correctly shows on taskbar of monitor where the window was active.
2) Understood about colors; thanks.
#5 Re: PSPad unicode 5.0.0 (174) English
Posted by: Freeman | Date: 04/08/2017 17:42 | IP: IP Logged
With build 171, menu font became larger and menu became annoying for me. Same issue with popup menus. Rolled back to 163.
image image
Edited 1 time(s). Last edit at 04/08/2017 17:42 by Freeman.
#6 Re: PSPad unicode 5.0.0 (174) English
Posted by: pspad | Date: 04/08/2017 20:52 | IP: IP Logged
Freeman:
Do you use high DPI?
Have you tried to choose smaller icon set for menu? I think you have too big icons for your menu items
#7 Re: PSPad unicode 5.0.0 (174) English
Posted by: Freeman | Date: 04/09/2017 01:11 | IP: IP Logged
I use 111% custom DPI on my 2K monitor, as I said before.
Silk_24 icon set has been chosen in both cases, I've changed only exe.
#8 Re: PSPad unicode 5.0.0 (174) English
Posted by: pspad | Date: 04/09/2017 06:55 | IP: IP Logged
Freeman:
Sorry, I am not able to remember hardware of all PSPad users. I will try to simulate it
