You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (171) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 04/04/2017 11:16 | IP: IP Logged
MadCompie:
While using this build 5 for a week now I did not receive "memory access violation" messages & terminations anymore... good news!!!
Tank you for message
#12 Re: PSPad unicode 5.0.0 (171) English
Posted by: Macari | Date: 04/04/2017 21:32 | IP: IP Logged
fresh install get error in new tab
www2.pic-upload.de
1. open pspad
2. open a php-file
3. new file (blank tab)
4. set windows 10 in hibernate mode
5. start windows
6. see tab is damaged
#13 Re: PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 04/05/2017 03:32 | IP: IP Logged
This is caused using old pspad and new one together. You have registered old one or opening files.
#14 Re: PSPad unicode 5.0.0 (171) English
Posted by: Macari | Date: 04/05/2017 06:30 | IP: IP Logged
Ahh, okay. I have clicked in taskbar on pspad4 icon. Thats create this damaged tab. smiling smiley
Edited 1 time(s). Last edit at 04/05/2017 06:40 by Macari.
#15 Re: PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 04/05/2017 07:16 | IP: IP Logged
One / PSpad is registered in Windows context menu.
If one instance is running, next PSPad run send into running instance file name only.
And cause 4 version works with ansi messages arguments and version 5 with unicode arguments, result is wrong file name in tab.
You are right, PSPad is portable, but doesn't work 4 and 5 together.
#16 Re: PSPad unicode 5.0.0 (171) English
Posted by: metrino | Date: 04/05/2017 08:21 | IP: IP Logged
Hi. Bugfix regression in code explorer SQL parser.
you shouldn't grab keywords in block/line comments.
Example:
t_TabWithSequence CART_PROG.ct_subst_tab := CART_PROG.ct_subst_tab(); -- LIsta delle Tabelle che utilizzano Sequence per la generazione degli ID
The keyword "Sequence" is inside a line comment, but the code explorer gets a "per" named sequence declaration.tongue sticking out smiley
#17 Re: PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 04/05/2017 08:52 | IP: IP Logged
metrino:
Example:
I will fix it
#18 Re: PSPad unicode 5.0.0 (171) English
Posted by: Macari | Date: 04/05/2017 09:58 | IP: IP Logged
Open pspad5 double click an a scss-file in left file browser and get a tab with this and the file content is empty
www2.pic-upload.de
this problem is with all scss files. restart pspad5 not help.
#19 Re: PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 04/05/2017 10:17 | IP: IP Logged
Macari:
www2.pic-upload.de
Cause you use odl and new PSPad together. I guess you have SCSS associated with old PSPad and this send it into new one you open it.
Fix association.
#20 Re: PSPad unicode 5.0.0 (171) English
Posted by: Macari | Date: 04/05/2017 10:25 | IP: IP Logged
Oh.. that not good. The intern file browser in pspad use externals? When I double click on a file in pspad I want open it in pspad, not start it with a external program. ;)
