You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (171) English
Posted by: pspad | Date: 2017-04-01 10:06 | IP: IP Logged
Download links (5.2 MB):
Changes to 5.0.0 (163)
News
External help for language in form of URL address accepts new %uword% and %lword% (current word changed to uppercase or lowercase)
New hierarchical Code explorer for TeX language family (LaTeX, ConTeX, ...)
HTML TiDy was updated to version 5.4
Development environment Delphi was upgraded from Delphi 10 Seattle to Delphi 10.2 Tokyo
Help for language in the URL form doesn't send current word in %word% variable
Special highlighter settings
Show special chars + TabWidth=2 with small letters - part of letter behind tab was overwritten
Posted by: tmtisfree | Date: 2017-04-01 19:49 | IP: IP Logged
The version reported by PSPad is 117, a typo probably.
Posted by: pspad | Date: 2017-04-01 19:54 | IP: IP Logged
tmtisfree:The version reported by PSPad is 117, a typo probably.
You are right, fixed.
Posted by: MegaV0lt | Date: 2017-04-02 12:59 | IP: IP Logged
Thank you very much for the fix in the highlighter for unix bash script. Looks good again:
Es gibt zwei Methoden, fehlerfreie Programme zu schreiben. Aber nur die dritte funktioniert. [Murphy's Computer-Gesetz]
Posted by: pspad | Date: 2017-04-02 13:03 | IP: IP Logged
MegaV0lt:Thank you very much for the fix in the highlighter for unix bash script. Looks good again:
I am glad it works too
Posted by: bbserv | Date: 2017-04-02 15:56 | IP: IP Logged
On my 4k laptop the dropdown menu text is too large. Is there a way I can fix this?goo.gl
Joe Berry
Posted by: pspad | Date: 2017-04-02 16:12 | IP: IP Logged
bbserv:On my 4k laptop the dropdown menu text is too large. Is there a way I can fix this?goo.gl
It's very strange the main menu item are small and submenu items are big.
Go to program settings / Program 1
Uncheck [ ]Show icons in menu
Was it same in previous build too?
Edited 1 time(s). Last edit at 2017-04-02 16:14 by pspad.
Posted by: pspad | Date: 2017-04-02 16:22 | IP: IP Logged
I tested it with own DPI on Windows 10 virtual machine. I got this state only in case I set own high DPI and don't logout as was suggested. When I logout/login, all was ok.
Posted by: bbserv | Date: 2017-04-03 13:30 | IP: IP Logged
Changed show icon settings and all is normal. Thanks for the prompt response.
Joe Berry
Posted by: MadCompie | Date: 2017-04-04 10:42 | IP: IP Logged
While using this build 5 for a week now I did not receive "memory access violation" messages & terminations anymore... good news!!!
