You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (147) English
Posted by: mali_zeeko | Date: 2017-03-24 18:46 | IP: IP Logged
vbr:mali_zeeko:When I open c/c++ source file larger than 500kB (e.g. sqlite3.c), c/c++ highligter is not applied to code, although status bar shows C/C++.Hi,
you can adjust the limit for automatic highlighting after loading the file in
Settings... [Direct edit]
Special settings:
HLOnUpToSize=500000You can still activate the highlighting for larger files manually - just with clicking on the respecive status bar field and confirming the highlighter settings.
hth,
Thank you. It works!
Posted by: mali_zeeko | Date: 2017-03-24 18:50 | IP: IP Logged
Is there a way to add new c++11 keywords into C/C++ highlighter?
nullptr, constexpr, override, final, noexcept, ...
Posted by: pspad | Date: 2017-03-24 19:49 | IP: IP Logged
mali_zeeko:Is there a way to add new c++11 keywords into C/C++ highlighter?
I found list of keywords here:
en.cppreference.com
and added it. Can you check if it's all you need please?
Posted by: mali_zeeko | Date: 2017-03-24 20:31 | IP: IP Logged
pspad:mali_zeeko:Is there a way to add new c++11 keywords into C/C++ highlighter?
nullptr, constexpr, override, final, noexcept, ...I found list of keywords here:
en.cppreference.com
Could you also add a list of C99 keywords:
en.cppreference.com
Posted by: human | Date: 2017-03-24 20:49 | IP: IP Logged
When adding keywords, can I suggest to resynch the multitude of keywords, and functions from COBOL?
System names, Keywords and function names: sourceforge.net
Additional keywords:
sourceforge.net and sourceforge.net
Posted by: pspad | Date: 2017-03-25 10:55 | IP: IP Logged
human:When adding keywords, can I suggest to resynch the multitude of keywords, and functions from COBOL?System names, Keywords and function names: sourceforge.net
Added + added about 114 new keywords for Cobol (GNU Cobol, Open Cobol)
Posted by: Macari | Date: 2017-03-25 17:53 | IP: IP Logged
I have a request. pspad 5 again freeze and after kill process all my task are disappeared and I must find all files (50+) again. I would be nice, when pspad save tablist with open and close files. After open pspad the tablist include files that was long ago closed. In numbers; Only 5 of about 50 tabs was found. 4 tabs are always included und one tab was completely wrong.
And close files with "close all files right side" is very slow. In all versions. With much files I must waiting 10-30s.
EDIT: And again crashed (not freeze) with "save all changed files".
Edited 1 time(s). Last edit at 2017-03-25 17:59 by Macari.
Posted by: pspad | Date: 2017-03-25 18:34 | IP: IP Logged
Macari:I have a request. pspad 5 again freeze and after kill process all my task are disappeared and I must find all files (50+) again. I would be nice, when pspad save tablist with open and close files. After open pspad the tablist include files that was long ago closed. In numbers; Only 5 of about 50 tabs was found. 4 tabs are always included und one tab was completely wrong.And close files with "close all files right side" is very slow. In all versions. With much files I must waiting 10-30s.
Download the latest build,. I fixed another bug.
You can use sessions - it allows you save set of files. You can have several sessions and open it.
You can use Project - project includes all open files even they are not included in project.
Posted by: human | Date: 2017-03-27 09:58 | IP: IP Logged
pspad:Added + added about 114 new keywords for Cobol (GNU Cobol, Open Cobol)
Nice. Just to let you know: it's GnuCOBOL
