You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (136) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 5.0.0 (136) English
Posted by: pspad | Date: 2017-03-22 18:00 | IP: IP Logged
Freeman:
Due to my custom DPI, I want to see MS Shell Dlg 2 (Tahoma) anywhere.
Some system controls like Menu, system dialogs e.t.c. doesn't support user menu font setting. So I am not able to fulfill your request.
If you want to have MS SHell dialog in menu, you need to set it in Windows settings.
#22 Re: PSPad unicode 5.0.0 (136) English
Posted by: Freeman | Date: 2017-03-22 18:26 | IP: IP Logged
I know. Forgot about it. I want Tahoma anywhere in dialogs. Menu is not a problem, it scaled by system.
Also a screenshot from old PSPad, I want something like in new one:
#23 Re: PSPad unicode 5.0.0 (136) English
Posted by: pspad | Date: 2017-03-22 19:12 | IP: IP Logged
Set Tahoma as font in the localization file
#24 Re: PSPad unicode 5.0.0 (136) English
Posted by: Freeman | Date: 2017-03-22 19:49 | IP: IP Logged
#25 Re: PSPad unicode 5.0.0 (136) English
Posted by: sandrosilveira | Date: 2017-03-22 20:32 | IP: IP Logged
Hello.
F4 doesn't close info window on my computer only if Prtuguese (Brazilian) as localization is chosen. This is caused by assigned "S" in Sim button as hotkey. I don't understand why F4 does Alt+S and continue search. If I open .\Language\Brazilian (Portuguese).ini and change line:
rs_Yes=&Sim to rs_Yes=Sim
it doesn't close information window anyway. I must investigate this strange behavior.
Perfect, We are using this as workaround!
Anyway. Can you please update Brazilian (portuguese) localization? If you open this file, look for ;;Translate comment. Each missing string is marked with this comment. Simple translate part behind "="
If there is a %s or %d, it's substitution for string or number - let it in translated string. As I saw, there is 35 untranslated strings.
I will send to you by e-mail our language file, with all 35 strings translated.
Thanks!
Sandro.
#26 Re: PSPad unicode 5.0.0 (136) English
Posted by: pspad | Date: 2017-03-22 21:01 | IP: IP Logged
Freeman:
I can do it, but it means I need to modify system dialog library.
