You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (133) English
Posted by: pspad | Date: 2017-03-17 11:41 | IP: IP Logged
Download links (2.9 MB):
Important
There is many changes in this version. It may contains bugs. Be carefull.
Changes to 5.0.0 (122)
News
Added anonymous program usage program tracking. You can switch it off in the program settings / Program 1. For now in developer builds only.
Code pages - added ISO 8859-2 autodetection
PSPad remembers height of File explorer file list box
PHP code explorer - added labels
HTML highlighter - added highlight matching MAIN
Hex Editor - Search/replace has been rewritten, fixed problem with 00 in search/replace
PSPad checks new version on start. Parameters are available in the Program settings / Check update
Pascal Code explorer - fixes related to block comment and directives
Clipboard monitor and shortcut problems (Del e.t.c.)
Hex editor - rewrited Search/Replace. Fixed problem with 00 in replace string
SpellCheck caused exception if stay active end you close all files and open new
MarkCurrentFileTab option (Special settings) works again
Posted by: pspad | Date: 2017-03-18 18:44 | IP: IP Logged
Analytics told me (exceptions) that many users unpack developer build into Program files folder. This is totally wrong, cause:
1. it caused exception is PSpad tries store config in batch convert (I handled it)
2. you lost most of functionality - developer builds contains changed files only
To prevent it, I will automatically switch on Multiuser environment if I will detect PSpad started from Program files folder.
