You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (122) English
Posted by: pspad | Date: 2017-03-14 07:50 | IP: IP Logged
Download links (2.9 MB):
Important
There is many changes in this version. It may contains bugs. Be carefull.
Changes to 5.0.0 (116)
News
User convertors are stored in .\Convertor subfolder with UTF-8 encoding. Conversion extended of regular expressions. See the file template.in_ for definition changes
removed few unsupported code pages
ASCII chart contains single bytes encodings
small fixes
Posted by: metrino | Date: 2017-03-14 09:29 | IP: IP Logged
Hi. Since v 116 I'm experiencing some strange freeze, duration is about 4-8 seconds, after that PSPad works again for some minute.
I'm running PSPad (32) on Win7 pro 64bit.
It never happened with < 5.0 versions
Posted by: MadCompie | Date: 2017-03-14 12:01 | IP: IP Logged
hello,
I have a little issue with this version :
when opening the file Plugins\FileType\ReadMe.txt, the filename is converted into a lot of some kind of Chinese characters...
This was while double-clicking on this file in Explorer. When dragging this file thru PSPad the filename is correct
Posted by: pspad | Date: 2017-03-14 12:12 | IP: IP Logged
MadCompie:hello,
This is caused but using old and new PSPad together.
You have old PSpad associated in Windows Explorer but you use new PSPad. When you click on file, Windows starts old PSpad with parameter and old PSPad sends file as ANSI name to new PSpad what awaits Unicode parameter.
Go to program settings / System integration, select integration method to registry and back to DLL and confirm.
Posted by: pspad | Date: 2017-03-14 12:13 | IP: IP Logged
metrino:Hi. Since v 116 I'm experiencing some strange freeze, duration is about 4-8 seconds, after that PSPad works again for some minute.
Do you have FTP connection active with TSL/SSL?
Posted by: metrino | Date: 2017-03-14 13:30 | IP: IP Logged
One SFTP connection is configured but it never worked before. However I rebooted PC, maybe some other hidden task was conflicting with PSPad.
I'll monitor the situation for a while.
Posted by: metrino | Date: 2017-03-14 15:37 | IP: IP Logged
Strange freezes are still here.
I tried to clean SFTP/FTP connections to be sure it doesn't try to connect for some reason, with no success.
The only thing that works in background is file changes checking, so maybe...
Posted by: Freeman | Date: 2017-03-15 09:30 | IP: IP Logged
I think, popup menu on double click on status bar isn't intuitive. Popup menu should appear on single click. Double click may be switch ANSI between UTF-8, but I'm not sure. Encodings to switch between may be customizable.
Posted by: pspad | Date: 2017-03-15 09:38 | IP: IP Logged
Freeman:I think, popup menu on double click on status bar isn't intuitive. Popup menu should appear on single click. Double click may be switch ANSI between UTF-8, but I'm not sure. Encodings to switch between may be customizable.
StatusBar has Single click or Double click functionality. It depends of Program settings / Program 2 - Statusbar functions require dblClick intead of singleClick. It's common for all status bar operations
Posted by: MadCompie | Date: 2017-03-15 11:43 | IP: IP Logged
THX!
pspad:MadCompie:hello,
This was while double-clicking on this file in Explorer. When dragging this file thru PSPad the filename is correctHello
You have old PSpad associated in Windows Explorer but you use new PSPad. When you click on file, Windows starts old PSpad with parameter and old PSPad sends file as ANSI name to new PSpad what awaits Unicode parameter.Go to program settings / System integration, select integration method to registry and back to DLL and confirm.
