You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (117) English
Posted by: khagaroth | Date: 2017-03-10 16:46 | IP: IP Logged
Ok, after some testing the problem is that the ASCII chart respects the setting for text color, but ignores setting for background color, hence white text on white background for me.
Posted by: pspad | Date: 2017-03-10 18:32 | IP: IP Logged
OK, colors are fixed.
I removed all non single byte code pages from ASCII chart.
Posted by: Solidornot | Date: 2017-03-10 22:12 | IP: IP Logged
...Just writing to confirm that Program Settings dialog looks properly scaled in the latest builds on my hi-res display, using 250% scaling under Windows 10.
Much thanks. Now back to using PSPad.
Posted by: vbr | Date: 2017-03-10 23:00 | IP: IP Logged
thanks for fixing the chatching of the compiler output;
it is working as expected now (Win 7).
regards,
Posted by: Freeman | Date: 2017-03-11 00:00 | IP: IP Logged
pspad:I removed all non single byte code pages from ASCII chart.
Nice!
Glad to see code page 866 by default. Second surprise -- saved Russian.ini with ANSI encoding get worked! I think, due to my system settings, with another system ANSI encoding it shouldn't work. Don't know, is setting like CodePage=1251 in ini-file really needed, just for ~20 KB benefit... But, if this feature remain work as semi-official hack, I will be completely glad.
You did great work, Jan. Thanks.
Posted by: Freeman | Date: 2017-03-11 00:04 | IP: IP Logged
Oh, I forgot about URL → Text and Base64 → Text, now working great! No more online encoders/decoders, I can do all work with PSPad.
Posted by: Freeman | Date: 2017-03-11 00:19 | IP: IP Logged
Jan, can you add separators between character set groups? For example, on right click on status bar popup menu:
ANSI
OEM
Unicode ...
Unicode ...
Unicode ...
ANSI ...
ANSI ...
ANSI ...
ANSI ...
ISO ...
ISO ...
ISO ...
OEM ...
OEM ...
Posted by: pspad | Date: 2017-03-11 04:51 | IP: IP Logged
Freeman:Jan, can you add separators between character set groups? For example, on right click on status bar popup menu:ANSI
OEM
Unicode ...
Unicode ...
Unicode ...
ANSI ...
ANSI ...
ANSI ...
ANSI ...
ISO ...
ISO ...
ISO ...
OEM ...
OEM ...
I dont think its necessary. You can customize your own set, it means you can drag/drop change order and select few for you uaefull CP for the menu.
Posted by: pspad | Date: 2017-03-11 07:40 | IP: IP Logged
Freeman:Glad to see code page 866 by default. Second surprise -- saved Russian.ini with ANSI encoding get worked! I think, due to my system settings, with another system ANSI encoding it shouldn't work. Don't know, is setting like CodePage=1251 in ini-file really needed, just for ~20 KB benefit... But, if this feature remain work as semi-official hack, I will be completely glad.You did great work, Jan. Thanks.
All CP and IDE manipulation is much easier now. I can focus effort on functionality instead of solve environment problems.
Posted by: pspad | Date: 2017-03-11 07:41 | IP: IP Logged
vbr:Hi,
regards,
I am really glad for this confirmation.
