You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (117) English
Posted by: pspad | Date: 2017-03-10 12:12 | IP: IP Logged
Download links (2.9 MB):
Important
There is many changes in this version. It may contains bugs. Be carefull.
Changes to 5.0.0 (116)
News
New ASCII chart with encoding selector, Unicode char value and HTML entities
Script Input Dialog with automatic history
Batch CP conversion (menu Encoding) was changed to non modal and allows you with Enter and DblClick open selected file from list
Compiler with catch output causes PSPad freeze on Windows 7
Posted by: metrino | Date: 2017-03-10 13:29 | IP: IP Logged
It looks like pspad version didn't change. It's still 116.
Forgot to change version label or zip file contains old binaries?
Posted by: pspad | Date: 2017-03-10 13:43 | IP: IP Logged
Sorry guys. Direct download is updated already, FossHub needs some time to synchronize
P.S. already synchronized.
Edited 1 time(s). Last edit at 2017-03-10 14:00 by pspad.
Posted by: AndreasW | Date: 2017-03-10 14:26 | IP: IP Logged
Have you changed the color of that little square by which bookmarked lines are indicated in the gutter? In previous versions it was yellow, now it's orange. I would like to change it back to yellow.
Posted by: metrino | Date: 2017-03-10 14:30 | IP: IP Logged
confirmed
Posted by: pspad | Date: 2017-03-10 14:56 | IP: IP Logged
AndreasW:Have you changed the color of that little square by which bookmarked lines are indicated in the gutter? In previous versions it was yellow, now it's orange. I would like to change it back to yellow.
I will find something between. In the previous version it was bitmaps, now i paint it to correctly resize bookmarks for High DPI displays
Posted by: khagaroth | Date: 2017-03-10 15:09 | IP: IP Logged
I'm getting empty ASCII chart. Well, It's not really empty (the entries are there and do show up if a cell is selected), but it renders as empty, ie. I get a visually empty table.
Posted by: pspad | Date: 2017-03-10 15:15 | IP: IP Logged
khagaroth:I'm getting empty ASCII chart. Well, It's not really empty (the entries are there and do show up if a cell is selected), but it renders as empty, ie. I get a visually empty table.
Your operating system?
Selected code page on the top of ASCII chart?
It's really 117 build? Can you add screenshot?
Does anybode else has a similar problem?
Posted by: khagaroth | Date: 2017-03-10 15:22 | IP: IP Logged
Yes, it's 117. On Windows 10, no system theme modifications. Codepage doesn't matter and while trying different codepages I also got this randomly:
Exception description:
Invalid code page.
Exception class:
Exception address:
Stack list, generated 10/3/2017 16:18:37
Thank you for your support!
Generically Information:
Please don't put such logs into the forum.
For mail address see PSPad > Help > About.
Also please describe what you have done to get this error.
Can you reproduce it every time?
Have you cross-checked with other PSPad versions?
Thanks
Program : C:\Program Files (x86)\PSPad\PSPad.exe 5.0.0 (117)
System : Windows 10 Professional x64, Version: 10.0, Build: 0,
Processor: Intel, Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, 3200 MHz MMX
Display : 1280x1024 pixels, 32 bpp
Active Controls Hierarchy:
TComboBox ""
TTabSheet ""
TPageControl ""
TfASCII ""
TPanel ""
TfPSPad ""
Edited 1 time(s). Last edit at 2017-03-10 19:51 by Stefan.
Posted by: Freeman | Date: 2017-03-10 16:06 | IP: IP Logged
pspad:Does anybode else has a similar problem?
On Russian Windows 7, have no problems.
New ASCII chart is great, but... wrong on DBCS codepages, e. g. Chinese or Japanese. Please restrict chart to SBCS only, or check leading bytes and display only single leading bytes, which has no trailing bytes. I know, these exist in Japanese, forgot about Chinese.
This is second PSPad alpha I've seen, will write more in evening.
