You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (116) English
#1 PSPad unicode 5.0.0 (116) English
Posted by: pspad | Date: 03/09/2017 14:31 | IP: IP Logged
Download links (2.9 MB):
Important
There is many changes in this version. It may contains bugs. Be carefull.
Changes to 5.0.0 (096)
Exception during favorite links load on PSpad start
SpellCheck caused exception
Settings dialog and HighDPI
Bookmarks and HighDPI
JScript code explorer - var declared functions
#2 Re: PSPad unicode 5.0.0 (116) English
Posted by: vbr | Date: 03/09/2017 15:06 | IP: IP Logged
Hi,thanks for enhancing the script dialog in this version!
The memory-combobox is realy useful for my scripts, however, there seem to be reduced space for a label. Some of my labels are rather long, with multiple lines, they are trimmed after the first two lines just now.
In any case, I like the combo list of this version; if necessary, I could adapt the extent of the labels in my scripts, if there were a hard limitation in the used control.
thanks and regards,
#3 Re: PSPad unicode 5.0.0 (116) English
Posted by: Stefan | Date: 03/10/2017 10:06 | IP: IP Logged
In Dialog "aBatchCPConvert_Caption=Batch encoding conversion"
I need 5 signs more space for
mCPAutoDetect_Caption=Autodetect CP
mCPAutoDetect_Caption=Kodierung automatisch erke
mCPAutoDetect_Caption=Kodierung automatisch erkennen
THX
#4 Re: PSPad unicode 5.0.0 (116) English
Posted by: pspad | Date: 03/10/2017 10:19 | IP: IP Logged
Stefan:
THX
OK
