You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.2 (2748) English
#1 PSPad unicode 4.6.2 (2748) English
Posted by: pspad | Date: 02/23/2017 10:24 | IP: IP Logged
Download links (2.9 MB):
Changes to 4.6.1 (2745)
News
New Code explorer type for Cisco IOS. You can set it up in the User Highlighter definition
Sort line (menu Edit) allows you sort lines by line length
Find Previous/Next - cursor doesn't jump in selected text but goes to Previous/Next occurrence
FTPS caused application hang up after long time (about 15 minutes) of inactivity
Insert Date/time dialog replaces "/" with "." for some regional settings
Unix Shell Script - fixed inline comment
File List (menu Window) doesn't activate existing file after dblclick
Editor PSPad - freeware editor, © 2001 - 2017 Jan Fiala
