You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.2 (2745) English
Posted by: pspad | Date: 2017-02-06 08:25 | IP: IP Logged
Download links (2.9 MB):
Changes to 4.6.1 (2743)
News
New option for File size limit confirmation in Program settings / Confirmation allows you to set file size limit. If file size is grater, PSPad shows confirmation dialog before file is loaded. Zero limit switch off this function.
FTP connection - Refresh button always reconnects FTP connection
Multiline File tabs
Preview from WebServer after PSpad start
FTP File list - year presentation on some non standard FTP servers
Posted by: metrino | Date: 2017-02-06 15:08 | IP: IP Logged
Multiline file tabs is OK
Many thanks
Posted by: pspad | Date: 2017-02-06 16:28 | IP: IP Logged
metrino:Multiline file tabs is OK![]()
Many thanks
Thank you for confirmation. Different themes, different DPI...
Posted by: tmtisfree | Date: 2017-02-07 08:30 | IP: IP Logged
There is a nasty bug which keeps appearing after some hours of using PSPad (locally and remotly). It inserts some funny character (mostly 'ÿ', without the quotes) often just before a closing parenthesis (itself replaced by another more common character), see picture.
This also happens in the file explorer where a file name can be replaced by the same 'ÿ' character.
A user has already reports that bug in the forum (forum.pspad.com). I also sent 3 ou 4 bug reports about it.
Edited 3 time(s). Last edit at 2017-02-07 08:35 by tmtisfree.
Posted by: MadCompie | Date: 2017-02-10 11:48 | IP: IP Logged
ftp year = cool! thx!
Posted by: tmtisfree | Date: 2017-02-11 12:51 | IP: IP Logged
I get this crash once a day:
Systems: Win7 Pro x64 and Win8 x64
Will try to send a log.
Edited 1 time(s). Last edit at 2017-02-11 12:51 by tmtisfree.
Posted by: MadCompie | Date: 2017-02-12 09:45 | IP: IP Logged
Me too... access violation...very often ... once a day... once a week but very annoying
i also use it on win7 64b
Edited 1 time(s). Last edit at 2017-02-12 09:46 by MadCompie.
Posted by: G00fY | Date: 2017-02-15 08:56 | IP: IP Logged
Also getting access violations. Think I can reproduce it when opening two files in textdiff ans scrolling to the bottom:
Exception class:
Exception address:
Stack list, generated 15.02.2017 09:46:39
Thank you for your support!
(See forum.pspad.com)
Also please describe what you have done right before
and how often that error occurs.
Thanks
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 4.6.2 (2745)
System : Windows 10 Professional x64, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 3100 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TPanel ""
TfChildDiff ""
Edited 2 time(s). Last edit at 2017-02-16 11:56 by Stefan.
Posted by: Andreas | Date: 2017-02-15 13:53 | IP: IP Logged
Hi Jan,
I'm also getting access violations with 4.6.2 (2745) from time to time. Should we all post this error stack list when we happens?
Edited 1 time(s). Last edit at 2017-02-15 13:53 by Andreas.
Posted by: pspad | Date: 2017-02-15 14:19 | IP: IP Logged
Don't post is here, send it to support mail with description what did you do when it happened
