You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.2 (2743) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.6.2 (2743) English
Posted by: pspad | Date: 2017-01-20 14:32 | IP: IP Logged
Download links (2.9 MB):
I am very sorry for slow development. I am overloaded with work in my job just now. I hope it will be OK soon again.
Changes to 4.6.1 (2741)
Known issues
problems with new CSS highlighter
News
updated CSS highlighter
Comments in UnixShell script highlighter
Fixed caption in Program settings / Editor 2 for Autocomplete confirmation
Left tool panel icons and tabs width with high DPI
File tabs height with high DPI
Ruller font size with high DPI
Edited 1 time(s). Last edit at 2017-01-23 09:00 by pspad.
#2 Re: PSPad unicode 4.6.2 (2743) English
Posted by: programmer9 | Date: 2017-01-20 18:41 | IP: IP Logged
I don't want to hassle you Jan, but should the Search/replace in files problem be fixed in this latest build or will that only happen in the next full release?
To recap - if a file has the following text in it:
12345 1234
and the 12345 is highlighted by double-clicking it, "Search/Replace is Files..." is used to actually search for this text then the 1234 'word' is highlighted and "Search/Replace in Files..." is used the "Text to Find" box shows 12345 not 1234 as it should.
#3 Re: PSPad unicode 4.6.2 (2743) English
Posted by: programmer9 | Date: 2017-01-21 12:01 | IP: IP Logged
If it's any help:
If 1234 and 12345 are both in the list of strings that have already been searched for then there is no problem - highlighting 1234 puts 1234 into the "Text to Find" box and highlighting 12345 puts 12345 into the box.
If 1234 is in the list of previously found strings but 12345 is not in the list then highlighting 12345 actually puts 12345 into the "Text to Find" box.
#4 Re: PSPad unicode 4.6.2 (2743) English
Posted by: metrino | Date: 2017-01-23 16:36 | IP: IP Logged
File tab height is broken for me:
Edited 1 time(s). Last edit at 2017-01-23 16:37 by metrino.
#5 Re: PSPad unicode 4.6.2 (2743) English
Posted by: metrino | Date: 2017-01-23 16:51 | IP: IP Logged
PS: here you are settings, I don't know if they are right
[FilePos]
Width=1540
Height=840
Top=10
Left=30
Maximized=1
ChildMaximized=1
HTMLWidth=620
HTMLHeight=450
HTMLTop=10
HTMLLeft=10
ForceFirstMonitor=0
IconSet=PSPad classic
AutoSavePos=0
TBIconSet=PSPad classic
LastScreenDPI=96
#6 Re: PSPad unicode 4.6.2 (2743) English
Posted by: Gorlash | Date: 2017-01-26 22:22 | IP: IP Logged
Aha!! I have the same issue, I posted an entry in Bug Reports on it.
I should have read here first !
Mine looks like this:
www.flickr.com
BTW, how do you pose the image in the file?? I couldn't get it to work...
#7 Re: PSPad unicode 4.6.2 (2743) English
Posted by: metrino | Date: 2017-01-27 09:20 | IP: IP Logged
@Gorlash I used imgsafe.org and img tag with url I got
#8 Re: PSPad unicode 4.6.2 (2743) English
Posted by: Greg | Date: 2017-01-30 20:12 | IP: IP Logged
Hello guys,
unless i've done something wrong, i don't think the comments in UnixShell script highlighter has been fixed.
I don't know if my exemples were enough well described. I'll try again :
"# Comment" means "[BEGIN OF LINE]#[SPACE]Text is commented"
#Not comment means "[BEGIN OF LINE]#[NO SPACE]Text is not commented"
# Not comment means "[SPACE]#[SPACE AND NO SPACE]Text is not commented"
I'm sorry if this looks like nothing understandable... I'm trying in english ;)
Thanks anyway because i know you said you watched it Jan.
(i hope it's not a problem from my end)
#9 Re: PSPad unicode 4.6.2 (2743) English
Posted by: pspad | Date: 2017-01-31 17:13 | IP: IP Logged
This link whows me different informations about comment:
forum.pspad.com
So I will return previous state before changes in this build.
#10 Re: PSPad unicode 4.6.2 (2743) English
Posted by: Greg | Date: 2017-01-31 17:56 | IP: IP Logged
Thank you.
Goto Page: 1 2 Next
