You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.2 (2741) English
#1 PSPad unicode 4.6.2 (2741) English
Posted by: pspad | Date: 2017-01-15 11:26 | IP: IP Logged
Download links (2.9 MB):
I am very sorry for slow development. I am overloaded with work in my job just now. I hope it will be OK soon again.
Changes to 4.6.1 (2739)
News
New user highlighter PowerPro including Code explorer
Opt in/out live spell check runs UNDO command
Gutter line number alignment with editor lines for ExtraLineSpacing > 1
When computer is locked or suspended, all background actions are stopped
#2 Re: PSPad unicode 4.6.2 (2741) English
Posted by: ivo | Date: 2017-01-15 14:08 | IP: IP Logged
Hello Jan.
I recently bought a Lenovo laptop with highdpi display
My resolution is 3200x1800; app and font size is set to 250% (Windows 10 suggested value)
Viewing in PSPad has some flaws:
- height of the open file tabs is too small
- ruler font size is too small
- size of each "panel tool" tab is too small compared to that of the icons
- the "about..." popup is very small (minor)
- vertical spacing between menu items is a bit too big (minor)
I'll try to send you a screenshot; I have to use PSPad_64 icon set: they are a little big (a middle way would be desiderable) but any other icon set appears very tiny.
Anyway, there are configuration options to solve those problems?
Thank you in advance
Ivo
#3 Re: PSPad unicode 4.6.2 (2741) English
Posted by: pspad | Date: 2017-01-15 16:20 | IP: IP Logged
I will try to simulate and fix it.
In this moment you can fix your menu - go to program settings / Program 1 and change icon set for menu - choose smaller icons
#4 Re: PSPad unicode 4.6.2 (2741) English
Posted by: Greg | Date: 2017-01-17 08:36 | IP: IP Logged
First, thank you very much for the INI style comment in user Highlighter in the previous build smiling smiley
I've seen some evolutions in the French translation, it's way better considering the french rules. Just one character missing there :
"aRemoveDuplicitiesCI_Caption=Retirer les lignes doublons (inensible à la casse)"
should be :
"aRemoveDuplicitiesCI_Caption=Retirer les lignes doublons (insensible à la casse)"
(the word "inensible" does not exist, it's "insensible")
#5 Re: PSPad unicode 4.6.2 (2741) English
Posted by: Greg | Date: 2017-01-19 13:50 | IP: IP Logged
I've just seen a different behaviour for the UNIX Shell Script Highlighter.
For the comment to be seen as one, we need :
- First character of the line is # and there is a space between # and the next character :
# Comment
#Not comment
# Not comment
or
- If # is not the first character in line, it needs to have at least one character AND a space before it to be seen as comment :
toto # Comment
toto #No Comment
For what i could see in .sh files, comments with # are seen like it no matter if # is the first character of the line, and no matter if it's followed by s space.
#6 Re: PSPad unicode 4.6.2 (2741) English
Posted by: pspad | Date: 2017-01-19 14:19 | IP: IP Logged
Thank you for examples. I will fix it.
#7 Re: PSPad unicode 4.6.2 (2741) English
Posted by: pspad | Date: 2017-01-19 14:53 | IP: IP Logged
Fixed. Available in the next build.
#8 Re: PSPad unicode 4.6.2 (2741) English
Posted by: gwinkless | Date: 2017-02-13 13:26 | IP: IP Logged
If this was aimed at my problem where RDP sessions would result in PSPad crash, I'm sorry to say I just had the same problem with the latest build :(
#9 Re: PSPad unicode 4.6.2 (2741) English
Posted by: pspad | Date: 2017-02-13 14:22 | IP: IP Logged
I found another problem, related to FTP with TSL/SSL. It causes PSPad freeze. Is ityour problem too?
