You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.2 (2735) English
Posted by: pspad | Date: 2016-11-24 20:11 | IP: IP Logged
Download links (2.9 MB):
I am very sorry for slow development. I am overloaded with work in my job just now. I hope it will be OK soon again.
Changes to 4.6.1 (2730)
News
ABB Rapid - code explorer extended of local procedures and traps
new action aRemoveDuplicitiesCI - removes duplicated lines as case insensitive
Link panel - added few shortcuts for open link (Enter), open link in default application (Alt+Enter), edit link (Ctrl+Enter)
New icon set PSPAD_64 for 4k displays
Log window size in memo mode
Unix Shell Script - fixed inline comment
FTP connect from menu in case FTP window is closed
Statusbar - line number was trimmed in 4k resolution
Code parser for PL/SQL - fixed sequence parsing
Code parser for C++ - function starts with "switch" wasn't included
Text diff with disk content - with external tool is content of the window stored to temporary file first
Edited 2 time(s). Last edit at 2016-11-25 16:13 by pspad.
Posted by: ok1 | Date: 2016-11-26 06:47 | IP: IP Logged
Thanks for update. Appreciate you are busy and have a life outside of maintaining PsPad.
Posted by: programmer9 | Date: 2016-11-29 17:21 | IP: IP Logged
The problem with Search and/or replace in files" reported for the last version is still present.
With the word qwerty in the text highlight qwerty and then click "Search and/or replace in files" - the "Text to Find" box shows qwerty.
Now select just qwert, click "Search and/or replace in files" and the "Text to Find" box still shows qwerty rather than the selected text (qwert).
This problem does not exist with the "Text search" tool.
Posted by: pspad | Date: 2016-11-29 18:34 | IP: IP Logged
programmer9:The problem with Search and/or replace in files" reported for the last version is still present.With the word qwerty in the text highlight qwerty and then click "Search and/or replace in files" - the "Text to Find" box shows qwerty.
I know, but I am going through mails and fixing one problem for another one. It's in queue yet.
Posted by: programmer9 | Date: 2016-12-01 22:07 | IP: IP Logged
pspad:programmer9:The problem with Search and/or replace in files" reported for the last version is still present.With the word qwerty in the text highlight qwerty and then click "Search and/or replace in files" - the "Text to Find" box shows qwerty.
Apologies, I didn't mean to hassle you but thought that the problem had been overlooked.
Many thanks for all your good work.
Posted by: pspad | Date: 2016-12-02 05:07 | IP: IP Logged
There is no necessary to appologize.
Posted by: pspad | Date: 2016-12-02 11:28 | IP: IP Logged
Problem was fixed. Wait for next build
Posted by: programmer9 | Date: 2016-12-04 18:10 | IP: IP Logged
pspad:Problem was fixed. Wait for next build
Thank you. Your efforts are much appreciated.
Posted by: Greg | Date: 2016-12-06 19:45 | IP: IP Logged
Hello Jan,
(that's Greg from the INI comment request)
This week i have worked on RegExp and i've seen two thinks PSPad doesn't do
It doesn't understand lookahead nor lookbehind assertions and, more importantly for what i had to do, RegExp \r\n does not permit me to replace CR and LR to have my text on one line.
Did you know those anomalies (if you see those as ones) and do you think you could spare some time to make it work ?
Before i go i have to thank you for all the work you've done making this amazing editor, my favorite ;)
Regards
Posted by: Andreas | Date: 2016-12-06 20:36 | IP: IP Logged
Till then you can use phreplace phdesign.com.au . This works great and very fast. Don't forget to register the phreplace.dll in your windows.
Register phreplace.dll in Windows 10
Open cmd als administrator
Type in:
regsvr32 "C:\Portable\PortableApps\PSPadPortable\phreplace.dll"
[ENTER]
Done
