You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.1 (2707) English
Posted by: pspad | Date: 2016-01-12 10:10 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
I am very sorry for slow development. I am overloaded with work in my job just now. I hope it will be OK soon again.
Changes to 4.6.1 (2703)
News
PSad FTP client uses FEAT command instead of HELP command to detect MLSD support
Communication Synedit library update - new TLS standards support
Menu Script is sorted alphabetically now
SafeFileSave (0/1) - new option in Special settings. Usage for synchronized folders, shared folders from virtual machines e.t.c. File is created into TEMP folder and coppied to target location. It means target is changed at once in one step.
Exception caused by text selection in TextDiff window
FTP file list without year fix for different timezones
Search in FTP list caused exception when FTP wasn't connected
Windows Shell Script - hyphenated-string in label
Removed missed message before external text diff tool starts
Real tabs in HTML multihighlighter
Posted by: MadCompie | Date: 2016-01-25 11:42 | IP: IP Logged
This release now sorts all scripts alphabetically (= a good thing) but it does not preserve the menu dividers...
addMenuItem "-", menuItem, "", "" 'Menu divider not shown anymore...
Posted by: syntech | Date: 2016-02-01 14:22 | IP: IP Logged
I'm using 2707 and noticed, that bracket highlighting is not working (for no bracket, na matter which type) for _SOME_ C/C++ file types?! Is this a bug or a problem in my side? I've checked the bracket color and it's still light blue. So I should see it. The strange thing is, in some files it works, in some not. They have all the same naming scheme, same file type (C/C++) and f.i. a file with 2.8k lines doesn't highlight the brackets whereas a file 10 times large does show it. So the file size doesn't seem to be a problem.
I can even open a new tab (new file) and hack away with a little if-statement with brackets, and the highlighting doesn't work here either.
Any ideas, please?
Ok, ok, this is kind of embarrassing. After I wrote the text above I checked the files again, and know what? The problem is line-wrapping. If it's active bracket highlighting doesn't work.
Is this supposed to (not) work that way?
Posted by: pspad | Date: 2016-02-01 16:32 | IP: IP Logged
Switch off wordwrap mode (Ctrl+W)
Posted by: pspad | Date: 2016-02-01 16:33 | IP: IP Logged
MadCompie:This release now sorts all scripts alphabetically (= a good thing) but it does not preserve the menu dividers...addMenuItem "-", menuItem, "", "" 'Menu divider not shown anymore...
I havn't any idea how should be menu dividers sorted
Posted by: MadCompie | Date: 2016-02-06 12:05 | IP: IP Logged
I think, the sort should happen between the given dividers (if any)
Example:
A1
B1
C1
D1
A2
B2
C2
D2
A3
B3
C3
Now with the new version this is:
A1
A2
A3
B1
B2
B3
C1
C2
C3
D1
D2
Posted by: lpatrick | Date: 2016-02-07 07:48 | IP: IP Logged
The real tabs in HTML multihighlighter seem to work correctly now!
Thanks a million, Jan!
