You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2674) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-10-02 07:29 | IP: IP Logged
Open program settings / Direct edit
change value of variable OldSpecialChars=1
#12 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-10-02 07:49 | IP: IP Logged
Freeman:
Right edge wasn't visible with cursor edge active
Yeah, it works! But... permanent vertical line is annoying... When coding, vertical line is needed only for indentation checks. Would you add a shortcut to make line visible only when some key is pressed?
Next build will contain new action:
aRightEdgeToCursor with caption: Set right edge to cursor position
In the program settings / KeyMap / Show you can assign shortcut and use it for quick set of right edge
Edited 1 time(s). Last edit at 2015-10-02 07:50 by pspad.
#13 Re: PSPad unicode 4.6.0 (2674) English
Posted by: janaco | Date: 2015-10-02 08:13 | IP: IP Logged
Thanks! You made my day(s)!
Sadly the Font Hack is not compatible with this setting. But a font-change to SourceCodePro helped.
janaco
#14 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-10-02 08:13 | IP: IP Logged
programmer9:
The "Text to Find" and "Selected Directory" drop-down boxes of the "Select/Replace in Files..." function still don't update to show the latest search string or folder respectively at the top of the lists the next time the function is used. The "Select/Replace in Files..", for me, worked really well until changes were made a few builds ago, since then it has been broken in different ways.
PSPad 2674, Windows 7 64-bit Professional
Does no one else have this problem?
I found and fixed bug. Wait for the next build.
#15 Re: PSPad unicode 4.6.0 (2674) English
Posted by: programmer9 | Date: 2015-10-04 10:00 | IP: IP Logged
programmer9:
Thank you Jan.
#16 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-10-04 11:12 | IP: IP Logged
programmer9:
programmer9:
Thank you Jan.
Can you confirm the current full version is OK?
#17 Re: PSPad unicode 4.6.0 (2674) English
Posted by: programmer9 | Date: 2015-10-12 17:34 | IP: IP Logged
programmer9:
programmer9:
Thank you Jan.
Sorry for the delayed reply, I have been away on holiday for a few days.
I have just installed build 2700 and this behaves correctly. Thank you.
