You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2671) English
Posted by: pspad | Date: 2015-09-18 11:21 | IP: IP Logged
Clicking on the ruller you see standard right edge. New functionality is second line which moves automatically with cursor.
Posted by: crimson | Date: 2015-09-18 15:36 | IP: IP Logged
Yes, I can see the line moves with cursor.
Posted by: Freeman | Date: 2015-09-19 09:11 | IP: IP Logged
pspad:New functionality is second line which moves automatically with cursor.
When I turn this feature on, the right edge line disappears, but one or more phantom vertical lines are drawing over the text. These phantom lines exist in addition to normal vertical line, moving with cursor.
Posted by: pspad | Date: 2015-09-19 09:31 | IP: IP Logged
Disappearing line is bug. It's fixed already and it will be available in the next build.
Can you please send me screnshot with fantom lines?
Posted by: Freeman | Date: 2015-09-20 07:50 | IP: IP Logged
Posted by: pspad | Date: 2015-09-20 08:34 | IP: IP Logged
For my optinion, it isn't fantom line, but standard Right edge.
Open program settings / Editor 2 and check position of Right edge. Standard position is 80.
If you click on the ruller (in your case is hidden), you can change position of the right edge for your file
Posted by: Freeman | Date: 2015-09-20 11:05 | IP: IP Logged
pspad:Open program settings / Editor 2 and check position of Right edge. Standard position is 80.
I set it to 120, more appropriate for 1280 pixels on the screen. But when I turn on vertical line, right edge disappears or drawing at wrong place, looks like as phantom line.
Here is right edge on, another is phantom line outside text area:
Posted by: pspad | Date: 2015-09-20 11:46 | IP: IP Logged
[quote=Freeman]
[quote=pspad]
[/quote]
This is a bug. I will be fixed in the next build
Posted by: programmer9 | Date: 2015-09-21 09:14 | IP: IP Logged
The "Search and/or replace in files" now searches directories that are selected from the drop-down list (which fixes the previous problem) but:
a) when a directory is selected from the "Selected Directory" drop-down list it is not shown at the head of the list the next time the search is activated
b) new directories no longer seem to be added to the "Selected Directory" drop-down list
c) "Text to find" box entries that are not in the drop-down list no longer seem to be added to the list
d) "Text to find" entries that are selected from the drop-down list do not appear at the top of the list the next time the search is activated
Posted by: PascalR | Date: 2015-09-22 14:01 | IP: IP Logged
Jan,
i found the Problem!
I have set "Position of Right Edge" to 0. That prevents the
vertical line from beeing displayed!
Regards
Pascal
