You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.0 (2669) English
Posted by: PGomersall | Date: 2015-09-09 20:20 | IP: IP Logged
Jan,
Done a few installs; install release and then patched with 2669. When I open PSPad, there is no folder created in roaming. Has something changed (like settings saved elsewhere) that I missed or is this a bug?
Pete
Posted by: pspad | Date: 2015-09-10 04:08 | IP: IP Logged
If you use portable PSPad or developer build and you iwll put it into Program files folder, PSPad has no rights to write there.
Run PSPad as administrator (right mouse)
Go to program settings / System integration and check Multiuser environment
Posted by: myf | Date: 2015-09-22 22:17 | IP: IP Logged
Per-syntax real/virtual tabs settings introduced bug I spotted in subsequent dev buid: new or newly opened TXT files always uses virtual tabs despite real tabs is set globally, until settings are re-saved.
BTW, such setting is great. What about per-syntax or per-file UTF-8 BOM setting, that have been discussed earlier?
Edited 1 time(s). Last edit at 2015-09-22 22:20 by myf.
