You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.0 (2665) English
Posted by: Zmy | Date: 2015-07-07 08:24 | IP: IP Logged
I know that macros can be an unlimited number. I mean, that's the hotkeys.
I often use macros. But to call the manager and look (seek) in a long list need macro is very long. Therefore, I would like more hotkeys
Posted by: Zmy | Date: 2015-07-07 09:15 | IP: IP Logged
It would be very good if done button select file to Internal Browser.
And to TextDiff, also make buttons select files
Edited 2 time(s). Last edit at 2015-07-07 09:20 by Zmy.
Posted by: pspad | Date: 2015-07-07 10:27 | IP: IP Logged
Zmy:It would be very good if done button select file to Internal Browser.
I am sorry, but I don't understand. What button do you mean?
TextDiff is easy to use with right mouse on tab you want to compare with current tab
Posted by: sandrosilveira | Date: 2015-07-22 16:50 | IP: IP Logged
Hi Jan,
Thanks for improvements in PSPad. We have used the latest release for testing and found a small problem, see the report of a developer:
After updated PSPad, we noticed a difference in the search history functionality.
In this last version, if we search for a term (like "test") twice, it will be displayed two times in the search history.
If we make a new search, with the same word, it will be displayed three times in the search history.
In previous versions like 4.5.8, when we search the same word more times, in sequence, the search history shows it only once.
The way it works in the older version is much better, because the list of terms keeps only different words, making it cleaner and easier to use.
Is it possible to change this behavior?
An example can be seen in the following image:
drive.google.com
Edited 1 time(s). Last edit at 2015-07-22 16:50 by sandrosilveira.
Posted by: pspad | Date: 2015-07-22 17:12 | IP: IP Logged
I know this problem and it's fixed already. Wait for nect build please.
Posted by: bobbydj | Date: 2015-07-24 08:59 | IP: IP Logged
When I compare 2 files, there is a problem on the right side with the accentuated letters (but they are the same in reality) and the comparison give an highlighted green error:
dernière réception <--> derniÞre rÚception
Edited 1 time(s). Last edit at 2015-07-24 09:03 by bobbydj.
Posted by: sandrosilveira | Date: 2015-07-24 12:06 | IP: IP Logged
pspad:I know this problem and it's fixed already. Wait for nect build please.
Thank you!
Posted by: pspad | Date: 2015-07-24 13:07 | IP: IP Logged
bobbydj:Hi,
Open both files - you should see accented chars as they should be.
Click right mouse on the file tab you want to compare with active tab and choose Text Diff with active tab
Posted by: bobbydj | Date: 2015-07-30 08:09 | IP: IP Logged
Thank you
