You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2661) English
Posted by: irvitrad | Date: 2016-11-30 08:24 | IP: IP Logged
Is the 64 bits version already there or is there an older version that works under Windows 7 64 bit?
I cannot install the latest version (4.6.1)
wkr
Jos
Posted by: pspad | Date: 2016-11-30 09:00 | IP: IP Logged
PSPad works under Win64 without any problem.
I didn't receive any report that installer 4.6.1 doesn't work under any Windows version
Download ZIP (portable version)
Unpack it anywhere you need and run.
If you untack it into program files folder, run PSPad as administrator then, open program settings / System integration and check [x]Multiuser environment option
Posted by: irvitrad | Date: 2016-11-30 13:27 | IP: IP Logged
Thanks, but...I hace tried that. Cannot open zip file, is invalid...
Posted by: irvitrad | Date: 2016-11-30 13:38 | IP: IP Logged
I did manage to download and install 4.5.8 from cnet, that will do.
Posted by: pspad | Date: 2016-11-30 13:40 | IP: IP Logged
In this case the problem is in your side.
Just tested and ZIP is OK.
Clear your browser cache, cause if you didn't download it correctly first time, your browser won't download it again, but offer it to you from cache.
There are 2 sources on the pspad.com web, one from FossHub, second is direct download.
Posted by: irvitrad | Date: 2016-11-30 14:08 | IP: IP Logged
Thanks a lot, that did it!
