You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2660) English
#1 PSPad unicode 4.6.0 (2660) English
Posted by: pspad | Date: 2015-05-19 16:20 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2658)
News
PSPad will check file change after external application run - case when external application changes open file/s
Code explorer - added support for FiveWin
File Search dialog is not closed if no lines were found
BAT highlighter - fixes in echo line
File locking - missing information File is locked by another user during open
Edited 1 time(s). Last edit at 2015-05-20 05:45 by pspad.
#2 Re: PSPad unicode 4.6.0 (2660) English
Posted by: carbonize | Date: 2015-05-19 20:22 | IP: IP Logged
dialog Hledání v souborech se nezavre, pokud nebyl nalezen žádný výskyt
Carbonize
#3 Re: PSPad unicode 4.6.0 (2660) English
Posted by: pspad | Date: 2015-05-20 05:44 | IP: IP Logged
Thanks to my personal interpreter winking smiley
#4 Re: PSPad unicode 4.6.0 (2660) English
Posted by: Bobf | Date: 2015-05-20 05:46 | IP: IP Logged
The same to,
the seach window keeps open.
Can you please fix it?
many thanks Bob
#5 Re: PSPad unicode 4.6.0 (2660) English
Posted by: pspad | Date: 2015-05-20 06:06 | IP: IP Logged
This isn't bug, but intentional behavior. If no occurence is found the Find in files dialog stay open.
If you want to close it, pres ESC.
#6 Re: PSPad unicode 4.6.0 (2660) English
Posted by: Bobf | Date: 2015-05-20 06:26 | IP: IP Logged
Ok Jan,
so why has the behaviour changed from 2658 to 2660?
I like the old behaviour.
Would it be possible to get the old behaviour back?
rgs Bob
#7 Re: PSPad unicode 4.6.0 (2660) English
Posted by: pspad | Date: 2015-05-20 07:41 | IP: IP Logged
I will do it optionally
I think the switch on the search dialog can solve it.
#8 Re: PSPad unicode 4.6.0 (2660) English
Posted by: Bobf | Date: 2015-05-20 07:44 | IP: IP Logged
That's great!
many thanks Jan
rgs BobF
