You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2655) English
Posted by: pspad | Date: 2015-03-18 13:15 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2653)
News
Autocomplete was rewrited to unicode.
HTML templates - changed charset to utf-8
File locking with R/O attribute
Code clips (Ctrl+mezerník) - fixed list draw with extreme DPI
Autocomplete (Ctrl+J) - fixed list draw with extreme DPI
PSPad start with parameter in case PSpad is running, parameter starts with switch and path isn't enclosed by quotas
search in files dialog and selected text in editor wasn't filled in in search box
Posted by: Fred | Date: 2015-03-18 13:34 | IP: IP Logged
I suppose mezerník means space?
Posted by: pspad | Date: 2015-03-18 14:00 | IP: IP Logged
Fred:I suppose mezerník means space?
Yes, sorry. Missed translation
Posted by: Alex | Date: 2015-03-19 09:56 | IP: IP Logged
Great! Cyrillic Autocomplete is fixed now =)
Posted by: bobbydj | Date: 2015-03-25 10:30 | IP: IP Logged
Edited 1 time(s). Last edit at 2015-03-25 10:32 by bobbydj.
Posted by: bobbydj | Date: 2015-03-25 10:44 | IP: IP Logged
Hello, in the comparison of 2 texts, it isn't correct in the right side with accentuated letters.
Can you correct. exemple:
On the left side : 'l'année doit être renseignée
On the right side: 'l'ann‚e doit ˆtre renseign‚e
Posted by: pspad | Date: 2015-03-25 11:00 | IP: IP Logged
What is wrong on TextDiff?
I tested your example and I see green lines in compare window - it means there is a change in lines
