You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2529) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.5.9 (2529) English
Posted by: pspad | Date: 2015-02-17 21:03 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2528)
News
PHP highlighter - fixed missing keywords
TextDiff - exception on some computers
most of flicking was removed during windows resize
#2 Re: PSPad unicode 4.5.9 (2529) English
Posted by: pash | Date: 2015-02-18 12:22 | IP: IP Logged
Hi, found a "little Bug" when using column mode selection via alt key.
1. use alt to select some columns
2. copy via crtl-c to clipboard
3. use a cursor key to remove the selection
now selection mode is still column mode, but using a mouseclick at (3) to remove the selection, selection mode switches back to row selection mode.
I personally think it is best to also switch back to row mode when using a cursor key to remove the selection.
#3 Re: PSPad unicode 4.5.9 (2529) English
Posted by: komfa | Date: 2015-02-23 13:12 | IP: IP Logged
Hello Jan,
It seems to me, that the following Option won't work or is there a new setting.
using "pspad.exe file.txt /010" opens a file called file.txt \010.
using "pspad.exe file.txt -010" opens a file called file.txt -010.
I need this, like the documentation before:
/nnn or -nnn
After open file, goto line or position in HEX.
MG
Christian
#4 Re: PSPad unicode 4.5.9 (2529) English
Posted by: pspad | Date: 2015-02-23 15:25 | IP: IP Logged
I just tested it as:
pspad path\some_existing_file /100
PSPad opened file and jumps to line 100
pspad newfile.txt /100
PSPad opens new file and stay on the top, cause there is no line 100
pspad newfile.txt -100
PSPad opens new file called newfile.txt -100
in this case isn't possible for PSPad to recognize what user wants. This PSPad calling has no sense
#5 Re: PSPad unicode 4.5.9 (2529) English
Posted by: komfa | Date: 2015-02-24 13:42 | IP: IP Logged
Hello Jan,
this works only for the first start. If the file is already opened, then a new emtpy file is opened with a filename /<linenumber>
In Version pspad459b2517 everthing works fine.
first start:
pspad path\the_same_existing_file /100 -> PSPad opened file and jumps to line 100
pspad is still open and i do again:
pspad path\the_same_existing_file /101 -> PSPad jumps to line 101 in file path\the_same_existing_file
All Versions greater then pspad459b2517:
first start:
pspad path\the_same_existing_file /101 -> PSPad open a file "101" and did not jump to line 101
MG
Christian
#6 Re: PSPad unicode 4.5.9 (2529) English
Posted by: mce | Date: 2015-02-25 20:13 | IP: IP Logged
Hi Jan,
In this latest version 2529, whenever I open PSpad, the Toolbars Control, HTML and Macro appear on the second line, even though I move them around and put them all on first line.
I haven't encountered this issue in any if previous versions of PSpad, 2528 was ok.
Thank you,
Cristian
#7 Re: PSPad unicode 4.5.9 (2529) English
Posted by: pspad | Date: 2015-02-25 20:28 | IP: IP Logged
Try this exe:
#8 Re: PSPad unicode 4.5.9 (2529) English
Posted by: pspad | Date: 2015-02-26 13:01 | IP: IP Logged
komfa:
Hello Jan,
first start:
first start:
MG
Christian
Fix will be available in the next build
#9 Re: PSPad unicode 4.5.9 (2529) English
Posted by: mce | Date: 2015-02-26 16:48 | IP: IP Logged
Thanks, working now.
Thank you,
Cristian
#10 Re: PSPad unicode 4.5.9 (2529) English
Posted by: Andreas | Date: 2015-02-27 15:25 | IP: IP Logged
mce:
Same problem here.
Goto Page: 1 2 Next
