You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2519) English
#1 PSPad unicode 4.5.9 (2519) English
Posted by: pspad | Date: 2014-11-27 12:26 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2517)
News
Code explorer - added support for code notes. In the user highligher and Highlighter settings you can define string, defining notes in code (e.g. @ToDo). Rest of line behind this comment is taken as note and displyed in Code explorer.
CSS highlighter - added LESS comment support
selection to PHP variable conversion for one line (menu HTML/conversion)
start PSPad with file without path as parameter when PSPad instance is already running
Edited 1 time(s). Last edit at 2014-11-28 10:24 by pspad.
#2 Re: PSPad unicode 4.5.9 (2519) English
Posted by: Gorlash | Date: 2014-11-27 15:17 | IP: IP Logged
Yes, this appears to solve all problems with spaces in paths.
Also, the previously-solved issues with opening non-existent files in directories other than initial opening directory, appear to still be fixed.
Thank You!!!!!!!!
#3 Re: PSPad unicode 4.5.9 (2519) English
Posted by: carbonize | Date: 2014-11-28 10:16 | IP: IP Logged
Jan think you forgot to translate something in your opening post ;)
Carbonize
#4 Re: PSPad unicode 4.5.9 (2519) English
Posted by: pspad | Date: 2014-11-28 10:25 | IP: IP Logged
Sorry, fixed
