You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2517) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-23 09:21 | IP: IP Logged
I know, that the problem is in "Default language for non-Unicode programs".
I have set English there, because I need English as default system language.
But I DON'T have the problem with non-unicode version of PSPad. I have problem with PSPad unicode 4.5.9 (2517)!!!
Edited 2 time(s). Last edit at 2014-11-23 09:23 by DenTNT.
#12 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-23 09:41 | IP: IP Logged
Is there problem with other dialogs or with the program settings only?
PSpad is written in Delphi 7 which isnt native unicode. Unicode support is added there using unicode components. There can be a problem on some places with interface.
#13 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-23 09:50 | IP: IP Logged
Yes, additionaly I have the problem with context menu (right mouse button).
Russian.ini is in Russian-1251 codepage
All dialogs are in incorrect codepage
Edited 2 time(s). Last edit at 2014-11-23 09:55 by DenTNT.
#14 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-23 10:53 | IP: IP Logged
Context menu? Do you use Registry integration or DLL library way?
COntext menu is out of PSPad influence.
#15 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-23 15:17 | IP: IP Logged
No. Not system context menu - PSPad context menu:
Cut, Copy, Paste, Help for Language, Open selected file in default application, Text diff with this file and others...
Edited 2 time(s). Last edit at 2014-11-23 15:19 by DenTNT.
#16 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-23 16:20 | IP: IP Logged
DenTNT:
System menu, context menu e.t.c. uses system settings. i am not able to change font or charset for it. And couse you set English charset, you have problem with cyrilic letters there.
#17 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-23 17:40 | IP: IP Logged
Thanks for the answer, but tell me please, by this version of PSPad called UNICODE? smiling smiley
#18 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-23 17:56 | IP: IP Logged
Because is able to edit text in unicode. Previous version edited text in ANSI and save it as unicode. Now you can write with any code page together inside one document.
#19 Re: PSPad unicode 4.5.9 (2517) English
Posted by: DenTNT | Date: 2014-11-24 09:00 | IP: IP Logged
Oh! Now I understand. Thank you!
Are you going to do full UNICODE version of PSPad (i mean UI) in the future?
#20 Re: PSPad unicode 4.5.9 (2517) English
Posted by: pspad | Date: 2014-11-24 09:35 | IP: IP Logged
Ÿes, but it will be long process. I have to buy new Delúphi version, move all used component to Unicode and move PSpad code itself too.
