You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2513) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.9 (2513) English
Posted by: Marten | Date: 2014-11-11 12:46 | IP: IP Logged
An error line i.e. is (I deleted an ':'):
./source/Simulator.cpp: In member function 'void Simulator::run()':
./source/Simulator.cpp:21:6: error: expected ':' before 'switch'
switch (cmd) {
and the log parser settings are
%F:%L:*
the option Save All Files Before Compilation is enabled.
The file is reopened at line 21.
First saveing the file 'by hand' doesn't matter.
#22 Re: PSPad unicode 4.5.9 (2513) English
Posted by: pspad | Date: 2014-11-11 13:12 | IP: IP Logged
I hope I know the problem already.
If file includes path, and file exists, PSPad first look for the file name in open files. If file is open, PSpad will activate it, if not, PSPad will open it.
Open file has expanded file name, include drive e.t.c. But in your log is an relative file name. I must expand file name before opening file. It should help in case when PSpad will be able to expand the file name.
#23 Re: PSPad unicode 4.5.9 (2513) English
Posted by: Marten | Date: 2014-11-12 09:08 | IP: IP Logged
It looks as if you corrected the problem in build 2517?
#24 Re: PSPad unicode 4.5.9 (2513) English
Posted by: pspad | Date: 2014-11-12 11:17 | IP: IP Logged
Test it, if it works for you. I forgot to write it into change log, sorry.
Edited 1 time(s). Last edit at 2014-11-12 11:18 by pspad.
#25 Re: PSPad unicode 4.5.9 (2513) English
Posted by: Marten | Date: 2014-11-12 13:20 | IP: IP Logged
It works.
Thanks!
