You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2512) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.5.9 (2512) English
Posted by: pspad | Date: 2014-10-16 19:36 | IP: IP Logged
PGomersall:
Jan,
Any chance on getting the icon updated for the tray and the context menu?
I intentionally let the smallest icon as it was. I tried to replace it too, but it was too unimpressive
PGomersall:
I like your new icon sets by the way.
I am glad you like it. It means several hours I spent by painting icons wasn't wasted.
Edited 1 time(s). Last edit at 2014-10-16 19:52 by pspad.
#12 Re: PSPad unicode 4.5.9 (2512) English
Posted by: pspad | Date: 2014-10-16 19:39 | IP: IP Logged
Spleendrivel:
Btw, I would not normally be concerned about matching tags e.g., body, but I am "fixing" someone elses old code and they did not seem to bother with any type of formatting or tag order for that matter.
Use Tidy (menu HTML). It will help you to check and reformat your code, it's able to add missing pair tags e.t.c.
#13 Re: PSPad unicode 4.5.9 (2512) English
Posted by: Bolla | Date: 2014-10-20 13:17 | IP: IP Logged
if I select "PSPad" as icons for the toolbars, I get the classic icon set :(
I want the new set with small icons :(
#14 Re: PSPad unicode 4.5.9 (2512) English
Posted by: pspad | Date: 2014-10-20 14:12 | IP: IP Logged
Bolla:
PSPad is small icon set 16x16px
PSPad_24 is bigger icon set, 24x24px
Please ensure you have PSPad.bmp and PSPad_24.bmp in skin subfolder
#15 Re: PSPad unicode 4.5.9 (2512) English
Posted by: Bolla | Date: 2014-10-20 16:00 | IP: IP Logged
For some reason, in the zip file, PSPad.bmp and PSPad classic.bmp are the same
#16 Re: PSPad unicode 4.5.9 (2512) English
Posted by: pspad | Date: 2014-10-20 17:06 | IP: IP Logged
Bolla:
I am very sorry, it's my fault.
Here is the last version of icon sets:
www.dropbox.com
#17 Re: PSPad unicode 4.5.9 (2512) English
Posted by: Bolla | Date: 2014-10-22 09:58 | IP: IP Logged
Thank you, works like a charm!
#18 Re: PSPad unicode 4.5.9 (2512) English
Posted by: komfa | Date: 2014-10-23 12:18 | IP: IP Logged
mce:
Hi Jan,
Thanks for this new version. I think the code clips auto-completion is still not what it used to be, in the sense that it shows on shift+space list of clips even though the clips just start with the letters entered. I think before it worked better (using 2441 currently), if you entered something and it didn't match a clip name fully, it was not used.
The reason I need this is because I set auto-completion on Space (not shif+space) so if I type "in" space I don't need to see all the clips starting with "in". I need to be able to type in full code clip name like index and have it auto-completed, not partials.
Is this something that can be changed back to how it was?
Thank you,
Cristian
Hi Jan, i'm still use the Version 2441, because of the reason above. I'm using also the space key for "Run Clip" if the clip name matches exactly .
A question to auto completion: Is there a switch to show the wordlist always exactly like the words in the hightlight-definition, even when the "Words are Case Sensitive" is unchecked. Currently the wordlist is in upper case. I need color hightlighting with no case sensitive, and a autocomplition wordlist with the right case.
Thanks You
Christian
#19 Re: PSPad unicode 4.5.9 (2512) English
Posted by: pspad | Date: 2014-10-23 12:30 | IP: IP Logged
In the next build I will return it back. It means Run clip will work only in case you enter whole clip name and Shift+Enter.
#20 Re: PSPad unicode 4.5.9 (2512) English
Posted by: mce | Date: 2014-10-24 19:00 | IP: IP Logged
Please make sure we can still use Space (instead of Shift+Space) to auto-run the clips, as there was an earlier version after 2441 where we couldn't overwrite this anymore.
Thank you,
Cristian
