You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2507) English
#1 PSPad unicode 4.5.9 (2507) English
Posted by: pspad | Date: 2014-10-05 18:08 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2503)
News
New default icon set for the menu and toolbar. Old set is available as PSPad classic. I am preparing bigger toolbar buttons.
Code explorer - problems with a new option Refresh after file save in Program settings / Tools.
Fixed problems with drawing (e.g. scroll in Text diff) in Editor component
Cobol highlighter - cursor on * indicator causes painting first line on page as an comment
File name without path in program title in case PSPad was run with file without path as parameter
Find/Replace dialog in system with increased font size
#2 Re: PSPad unicode 4.5.9 (2507) English
Posted by: Andreas | Date: 2014-10-05 21:18 | IP: IP Logged
Attention! There are ini files in root. If you overwrite your ini files settings will get lost.
Jan, are those ini files necessary for this version update?
#3 Re: PSPad unicode 4.5.9 (2507) English
Posted by: pspad | Date: 2014-10-06 03:36 | IP: IP Logged
I am sorry Andreas, you are right. I updated package
#4 Re: PSPad unicode 4.5.9 (2507) English
Posted by: ok1 | Date: 2014-10-07 11:01 | IP: IP Logged
Really like this version and the earlier 2503 release smiling smiley
1) 2507 - Search/replace font sizes "fixed". For me they were a bit big in 2503
2) 2507 - Love the new icons, programs and tool bar.
3) 2503 - Seems much faster (to me at least).
The mixup with the .INI files took all of one minute to fix.
Don't use a lot of the advanced coding features but it is my favourite editor.
#5 Re: PSPad unicode 4.5.9 (2507) English
Posted by: Gorlash | Date: 2014-10-07 19:39 | IP: IP Logged
and my "loading new file with missing path" bug is fixed!! Huzzah !!!!!
smiling smileysmiling smileysmiling smiley
#6 Re: PSPad unicode 4.5.9 (2507) English
Posted by: m2u_germany | Date: 2014-10-09 09:03 | IP: IP Logged
Hi, I just noticed a small issue with this version (don't think it occured in earlier builds): If you select multiple files in Win Explorer and try to open them directly in PSPad via context menu the client only opens one file (the last one selected I think). Something with the parameter handling seems to be broken here.
Otherwise thanks for this latest build, great to see a fresh interface look btw.
#7 Re: PSPad unicode 4.5.9 (2507) English
Posted by: pspad | Date: 2014-10-16 06:30 | IP: IP Logged
m2u_germany:
Open program settings menu / System integration
Uncheck system integration, confirm, check integration via DLL extension and confirm.
DLL integration is much faster
