You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2503) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 14:31 | IP: IP Logged
Andreas:
ps I'm working with phpStylist in PSPad and this works much better - realy nice code formating like expected.
Ohhh. I am not webdesigner and nobody told me about phpStylist before sad smiley
#12 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 14:39 | IP: IP Logged
Andreas:
2504:
I removed my path variable and tried 2504. It works.
But: Same double content and indentation bug.
And: Content ist shown in a new file where you have to watch out to not again use the PHP beautifier else PSPad hangs and has to be closed with the task manager.
Doubled content isn't possible from my point of view.
Now it's pure call phpCB.exe with parameters and redirection into new file in batch.
At the present new file is open - it's for functionality check only.
This version:
www.dropbox.com
doesn't delete batch file nor result file. You can check the result.
#13 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 15:13 | IP: IP Logged
No double content with this version 2505.
No PSPad freezing when beautifying again in result PHP file.
But bad indentation errors and some newline errors.
And result in new file is not good, it should formate the code direct in the original file.
phpStylist:
I use phpStylist from dinofly forum.pspad.com
For this to work I've installed xamp (PHP module is enough)
You need those two files from dinofly (there's no new phpStylist version right now - 15.09.2014)
C:\myPSPadFolder\Plugins\phpstylist\phpStylist.php
C:\myPSPadFolder\Script\JScript\phpStylist.js
In phpStylist.js you have to set these two variables
php_path = "C:\\myXamppFolder\\php\\php.exe";
stylist_path = "C:\\myPSPadFolder\\Plugins\\phpstylist\\phpStylist.php";
Watch out for the double backslashes!
#14 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 16:09 | IP: IP Logged
Result in new file tab is temporary solution to easy see result between original and formated file.
I looked at phpStylist. The complication is it needs Web server installed.
#15 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 16:19 | IP: IP Logged
Sorry, now I saw that someday I slightly modified phpStylist.php for better results regarding alignment of variables and arrays and possibly indentation.
You can get it here
public.andreasburg.de/phpStylist.zip
ps This textarea editor is so bad. Is there a manual that shows what we can do with it? Markdown? I.e. it cuts off the rest of an URL and just shows the host.
#16 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 16:23 | IP: IP Logged
Yes I agree, but you can install xampp and in the installation only choose the PHP-Module. And you don't have to run the server.
Maybe you find a better solution but the formatter class should work correct and best is that it is still maintained.
#17 Re: PSPad unicode 4.5.9 (2503) English
Posted by: LekaNukem | Date: 2014-09-16 12:42 | IP: IP Logged
Turning off code explorer refresh on file save doesn't work.
It will refresh it either way, even when the option is turned off. If I restart PsPad, it will revert the setting back (because it was never really turned off?)
Any thoughts?
Thanks.
#18 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-16 13:25 | IP: IP Logged
LekaNukem:
Any thoughts?
Thanks.
Use workarround:
open program settings and press direct edit
On the left list click on Config. The last item should be:
CodeExplorerRefreshSave=1
change it to:
CodeExplorerRefreshSave=0
Confirm OK and confirm program settings dialog.
#19 Re: PSPad unicode 4.5.9 (2503) English
Posted by: mce | Date: 2014-09-16 17:56 | IP: IP Logged
Hi Jan,
I downloaded the latest portable version ((pspad458en.zip), and there is no "Scripts" menu entry anymore (between Tools and HTML).
I applied the latest (4.5.9 2503) version on top of it, Scripts still not there.
How do I access my scripts now? I copied a script to the Script\VBscript folder, but they are not runing anymore on the key shortcut I had.
Thank you,
Cristian
#20 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-16 18:15 | IP: IP Logged
mce:
Hi Jan,
Thank you,
Cristian
Go to program settings / System and enable scripting support.
If you want to keep your settings, you can use backup / restore of settings from program settings / Backup next time or simple replace old PSPad version with new one
