You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.9 (2501) English
#1 PSPad unicode 4.5.9 (2501) English
Posted by: pspad | Date: 2014-09-09 20:49 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2500)
News
Search/Replace dialog in files doesn't clear Replace flag and replace string
Cobol highlighter - Specification - added buttons for strict and free mode quick settings
File open exception dialog extended of system error message
HEX editor settings in Program settings - number of bytes per line and column can be freely set
Code Explorer - in Program settings / Tools is possible switch off refresh after file save
File locking - Save file as - fixed old and new file lock
MSDos batch highlighter - fixed bracket highlight with Echo inside of brackets
FTP client with MLSD file listing - fixed situation when file list is returned without file time information
#2 Re: PSPad unicode 4.5.9 (2501) English
Posted by: Neil | Date: 2014-09-09 21:44 | IP: IP Logged
News
Hi Jan,
Thanks very much for that.
Much appreciated - used it many times already !!
Question:
Is there a way to clear the search and find results ??
Thanks
Neil
#3 Re: PSPad unicode 4.5.9 (2501) English
Posted by: pspad | Date: 2014-09-09 21:50 | IP: IP Logged
Each Search in files will create new content of the Seach log, if option in Search/Replace in files / Clear previous search result is checked.
#4 Re: PSPad unicode 4.5.9 (2501) English
Posted by: Neil | Date: 2014-09-10 02:32 | IP: IP Logged
Ooops !! - I can't believe it - I've never noticed that before !!
Thanks for pointing it out.
Cheers,
Neil
#5 Re: PSPad unicode 4.5.9 (2501) English
Posted by: NorMos | Date: 2014-09-10 07:54 | IP: IP Logged
I am using PSPad for many years, usually the latest builds.
Is there an intended change at the log window from 2500 to 2501?
When compiling my project, I get an endless output to the log window.
Example:
Uhrzeit: 9:39:24,27
Compiling mc_entry...
PRIVATE ALLOCATION: LA 1240000 - 1370 Bytes - handle 22B1840
Leave loader...Exit loader
[Enter loader...In loader]
PRIVATE ALLOCATION: LA 1260000 - 250 Bytes - handle 2421FC0
PRIVATE ALLOCATION: LA 2220000 - 51BB0 Bytes - handle 2421FE0
(allocated 334759 bytes for fixup info)
PRIVATE ALLOCATION: LA 2170000 - 44000 Bytes - handle 2422000
PRIVATE ALLOCATION: LA 12B0000 - EA0 Bytes - handle 2422020
PRIVATE ALLOCATION: LA 2280000 - 1E000 Bytes - handle 2422040
LINEXE: Using DOS:Extended Startup Conditions...
Executing C:\MRI\MCC68K\CFE68K.EXE with initial registers:
TSF32: prev_tsf32 0
SS 30F DS 30F ES 18F FS 0 GS 17F
EAX 0 EBX 0 ECX 0 EDX 0
ESI 307 EDI 0 EBP 0 ESP 229D198
CS:IP 307:021AAB18 ID 00 COD 60A2798 FLG 200
CS= 307, USE32, page granular, limit FFFFFFFF, base 0, acc CFFB
DS= 30F, USE32, page granular, limit FFFFFFFF, base 0, acc CFF2
The result of compilation is ok, but the amount of output is a little bit confusing.
Thanks,
Norbert
#6 Re: PSPad unicode 4.5.9 (2501) English
Posted by: pspad | Date: 2014-09-10 08:09 | IP: IP Logged
The amount of ouput from your compiler depends of compiler. PSpad shows only what compiler sends to console output.
#7 Re: PSPad unicode 4.5.9 (2501) English
Posted by: NorMos | Date: 2014-09-11 05:24 | IP: IP Logged
Of course, that´s right, but I did no changes to compiler or batch file. There seems to be a difference between 2500 and 2501. If the batch file is executed directly in a DOS window the output is unchanged.
Thanks, Norbert
#8 Re: PSPad unicode 4.5.9 (2501) English
Posted by: pspad | Date: 2014-09-11 05:29 | IP: IP Logged
Can you please check parameters of your compiler? Usually is possible to set details in compiler output.
I did no changes in catching console output several versions.
#9 Re: PSPad unicode 4.5.9 (2501) English
Posted by: NorMos | Date: 2014-09-11 08:10 | IP: IP Logged
Thank you very much for the quick response. I will check the compiler settings. (I have to look for the documentation, the compiler is from the nineties, but I´m still using it.)
Have a nice day,
Norbert
