You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.8 (2471) English
Posted by: pspad | Date: 2014-04-08 13:24 | IP: IP Logged
Download links (2.7 MB):
code.fosshub.com
31.31.78.126
Changes to 4.5.8 (2469)
News
Scripting - getVarValue function extended of %Word% variable. It retunrs word under cursor
New user highlighter definition KRL (KUKA Robotic Language) with code explorer support
CSS reformat to structure - new lines for each selector
TiDy was updated for HTML5 support
Search in files - change of the search text in search process searched for the new text
MSDos BAT highlighter - fixed string and %%i variable highlighting
Check document changes function was fixed
Edited 1 time(s). Last edit at 2014-04-08 19:32 by pspad.
Posted by: vserghi | Date: 2014-04-08 19:15 | IP: IP Logged
Any chance of a translation ;)
Vas
Posted by: pspad | Date: 2014-04-08 19:32 | IP: IP Logged
Sorry
Posted by: pizzaman | Date: 2014-04-16 16:54 | IP: IP Logged
I like the program and it still runs great in Windows 8.1 (upgrade). It never crashes and i don't miss any features, so i'll keep using it for years to go.
My question: is the slow pace of new releases because there's simply no bugs to crush or do you have different priorities? Just out of curiosity
Either way, thanks for the great program.
Edited 1 time(s). Last edit at 2014-04-16 16:55 by pizzaman.
Posted by: pspad | Date: 2014-04-16 17:17 | IP: IP Logged
There were several major problems caused by Windows 8.1, wrong file change autodetection e.t.c.
Now I will fixx several minor problems and I will release new full version
Posted by: hankejh | Date: 2014-04-16 17:40 | IP: IP Logged
Hi Jan -- thanks again for all of you work!
I updated the Ingkcpos cursor enhancement script and uploaded to PSPad extensions:
Posted by: Bolla | Date: 2014-04-23 11:13 | IP: IP Logged
for some reason the "highlight matching brackets" is not working any more.
Don't know since which version :(
Am I the only one with this issue?
Posted by: pspad | Date: 2014-04-23 11:16 | IP: IP Logged
Matching brackets was disabled temporary in the wordwrap mode.
Posted by: Bolla | Date: 2014-04-23 11:33 | IP: IP Logged
Uhm... It seems to not be working in any case...
Posted by: Bolla | Date: 2014-04-23 13:42 | IP: IP Logged
Sorry, my mistake. Without wordwrap, it works
