You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2469) English
Posted by: pspad | Date: 2014-02-24 17:44 | IP: IP Logged
Download links (2.7 MB):
code.fosshub.com
31.31.78.126
Changes to 4.5.8 (2463)
News
Added detection of new OS versions
Code explorer will stay expanded as was before refresh
Number of user highlighters was increased to 10 from 5
CAPS lock indication on the status bar
Create project from folder will include empty folders too
Added program icons in higher resolution. In some cases is necessary to rebuild icon cache to see it
New function Remove diplicate lines (menu Edit / Lines manipulation) removes duplicate lines from text without sorting
New text file doesn't offer file name as first line
Function Save as doesn't change file time, if file already exists
JavaScript Code explorer fixies
Fixed Wine (Linux) functionality
FTP connection doesn't work with account parameter
Broken funts in Print preview window
Open File from selected text doesn't work for HTTPS://
Unix Shell Script highlighter - fix of the variable highlight
Posted by: Neil | Date: 2014-02-24 21:24 | IP: IP Logged
Hi Jan,
pspad:New:
Broken fonts in Print preview window
1. CAPs lock indicator - thanks - very handy for me !!
2. Fonts - Strange behaviour !!
Size 9 works as before.
Size 8 still does not work!!
But if I manually enter size 7 it works (don't know if this was the behaviour in previous PSPad version).
I would like to have font size 8 but size 7 is ok.
Thanks,
Neil
Posted by: mceps | Date: 2014-02-25 15:40 | IP: IP Logged
Hi Jan,
I'm still using build 2441, as all the newer builds, have this issue:
I use "space" to trigger clips instead of "ctrl-spacer", and if for example I have a code clip named "index" and I type "in" or "ind" then hit space (or ctrl-space for that matter), then the clip gets executed. So it seems the clips get executed when matching a beginning portion of the clip name, instead of matching the full clip name.
I think this bug or feature was introduced as a fix for another build which broke the "space" clip expansion, which I notified you about, now "space" clip expansion works, but not properly.
Thank you,
Cristian
Posted by: Tecno | Date: 2014-02-28 10:16 | IP: IP Logged
I can't see JCL highlighter option available in this version ?
Posted by: pspad | Date: 2014-02-28 11:27 | IP: IP Logged
Developer build is update only. Instruction you must apply it over existing full version are in any build information.
Do it please. JCL highlighter is included in full version of PSPad.
Posted by: Tecno | Date: 2014-02-28 13:27 | IP: IP Logged
thanks !
Edited 1 time(s). Last edit at 2014-02-28 13:31 by Tecno.
Posted by: Bolla | Date: 2014-02-28 17:02 | IP: IP Logged
Nice update, thank you!
Posted by: sandrosilveira | Date: 2014-03-27 14:15 | IP: IP Logged
Hi Jan,
After update from 2453 to 2469, I noticed a problem with syntax recognition in MS-DOS Batch:
After first quote character ("), all tokens until the end of line are treated like a String, and pspad doesn´t recognize matching parenthesis.
Quote:rem Some samples with problem:
if "%VAR%"=="B" (set X=Y)set A=1 & set B="n" & set C="m"
for /f "tokens= delims=," %%i in (*.exe) do (echo %%i)
if "%VAR%"=="N" (
if exist "test.txt" (
set VAR="Y"
rem This works because haven´t quotes characters (") in test
if exist test.txt (
echo file exist!
See the image with code colorized:
www.dropbox.com
Thanks in advance
Sandro
Posted by: pspad | Date: 2014-04-01 10:38 | IP: IP Logged
Thank you for an info.
I found a problem and fixed it. Fix will be available in the next build
