You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.7 (2449) English
Posted by: rhia | Date: 2013-01-17 09:38 | IP: IP Logged
rhia:Když potom označené Ă zkopíruju a vložím na stejné místo, znak jakoby zmizí a je to v pořádku.
Ă je v pořádku Ĺ pořád odskakuje
Posted by: carbonize | Date: 2013-01-17 09:49 | IP: IP Logged
No offence but can we keep the Czech posts in the Czech thread?
Carbonize
Posted by: Vany | Date: 2013-01-17 10:24 | IP: IP Logged
definitely.
Pokud chcete pokračovat v češtině, zkopírujte příspěvek do nového vlákna českého fora, prosím.
If you wish to continue in Czech, let's copy it into the new thread in the Czech phorum, please.
Posted by: vbr | Date: 2013-01-17 10:41 | IP: IP Logged
carbonize:No offence but can we keep the Czech posts in the Czech thread?
Sorry for cluttering the English forum.
As Jan mentioned, erroneously placed posts cannot be moved to other branches in this forum.
I initially preferred to answer to the original location to keep the context, but as there is a more complex problem and multiple posts, it is clearly appropriate to start a new thread instead.
I just created one:
Souhrn vybranych relevatnich prispevku k uvedenemu problemu je nyni v odpovidajicim ceskem vlakne:
forum.pspad.com
vbr.
Posted by: carbonize | Date: 2013-01-17 17:03 | IP: IP Logged
Yes I've had people tell me before about how Phorum is lacking in the ability to split and merge threads.
Carbonize
Posted by: Vany | Date: 2013-01-18 02:30 | IP: IP Logged
Thanx vbr!
Posted by: DrainX1 | Date: 2013-01-19 19:55 | IP: IP Logged
A suggestion that might be added would be releasing the code explorer definition files (or making it editable.) I know that I would LOVE to add some custom explorer tags.
Posted by: pspad | Date: 2013-12-05 08:02 | IP: IP Logged
Shadeclan:Jan,This version of PSPad no longer works in Wine. It continuely throwns the error "Internal Error: SyncHotKeyPosition Failed ("Fo&rmat" <> "Fo&rmát")."
Also the current stable version, V4.5.6 won't return from the minimize position. Not sure if it has other problems.
Fix will be available in the next developer build
