You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2447) English
Posted by: gnfpt | Date: 05/21/2012 15:48 | IP: IP Logged
I use PSPad to connect via FTP to a z/OS to edit some files.
It works fine but when the file is in a big directory (dataset) the FTP blocks until it parses the directory content that the ftp server communicated.
Even with a script, if I tell it to open a specific file in a big dataset, it loads the file but then blocks the ftp (and PSPad) refreshing the ftp window with the directory (dataset) content.
It may take a few minutes doing so which is very annoying.
On the next build can you change the FTP window to refresh the directory content asynchronously and change the openFileFromFTP() in a way that after retrieving the file it won't refresh the ftp window content?
Thanks,
~\gnfpt
Posted by: deanhill1971 | Date: 05/24/2012 17:36 | IP: IP Logged
I'm seeing a problem assigning commands to Ctrl+/. Right after the assignment, everything works. However, the assignment does nothing after PSPad is restarted.
I first saw the problem in 4.5.6 (2427), but upgrading to 4.5.7 (2447) has made no change.
To reproduce the problem:
1. Click Settings | Program Settings.
2. Select Search then double click Find.
3. For New Shortcut press Ctrl+/.
4. Click OK twice.
5. Test the change by pressing Ctrl+/ and doing a find. Everything should work.
6. Close and reopen PSPad.
7. Now press Ctrl+/. Nothing will happen. Click Search | Find from the men and find will work.
I've tried reassigning other commands and see the same problem.
Let me know if you can reproduce the problem. Thanks.
Posted by: padfox | Date: 08/07/2012 13:31 | IP: IP Logged
crimson:New function - Find file in project (menu project, file tab)I like this function. It's great to me.
thank you very much.
...yep, long awaited, many thanks!
Geetings
padFox
