You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.7 (2447) English
Posted by: pspad | Date: 2012-04-30 17:28 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.7 (2445)
News
MySQL highlighter - added data type boolean
Code explorer - added support for LUA
Oracle highlighter - added support for strings q'{ ... }'
New function - Find file in project (menu project, file tab)
PSPad will keep TXT file name sent as parameter
XML reformat - fixed problem with comments
Recent file list - fixed problem with lost content
Posted by: karminski | Date: 2012-05-01 06:29 | IP: IP Logged
Its ok, but there is a more urgent bug you must fix for a long time ago. pspad.nlift.com
What info do you need to analyze and fix this bug?
1C-Bitrix: web-site logic and interface developer
Edited 1 time(s). Last edit at 2012-05-01 06:29 by karminski.
Posted by: menet | Date: 2012-05-02 15:17 | IP: IP Logged
In English.ini and others langage files there was before :
mFTPNewFile_Caption=New file
mFTPRefresh_Caption=Refresh
Now these 2 lignes are replaced by the line :
mFTPNewFi
I suppose that something is missing because the "=" sign is not there !
Thanks for the evolutions in the product.
Posted by: pspad | Date: 2012-05-02 20:07 | IP: IP Logged
Thank you for info.
Posted by: crimson | Date: 2012-05-04 01:41 | IP: IP Logged
I like this function. It's great to me.
thank you very much.
Posted by: pspad | Date: 2012-05-04 04:35 | IP: IP Logged
crimson:New function - Find file in project (menu project, file tab)I like this function. It's great to me.
You can attach shortcut for this function to be quickly accessible
Posted by: menet | Date: 2012-05-04 17:17 | IP: IP Logged
menet:In English.ini and others langage files there was before :
mFTPNewFi
I have forgoten to ask : It is the old value (the 2 old lines) that should be set inside the language file or others new lines are missing or lines should be deleted ?
Can you write here the english lines to include to have good language file for this version.
Best regards
Posted by: pspad | Date: 2012-05-04 17:57 | IP: IP Logged
There are 2 missing lines instead one cutted as you mentioned before:
Posted by: 5haun | Date: 2012-05-07 23:49 | IP: IP Logged
Perl Syntax highlighting breaks in the middle of the following code:
if ($line =~ /^\s*
(\S+) # key
\s+=\s+ # =
\"([^"]+)\" # "value"
\s*$/x) {
my ($key, $value) = ($1, $2);
$settings->{$key} = $value;
Posted by: cebe | Date: 2012-05-11 10:25 | IP: IP Logged
This version of PSPad crash when a close à <a> tag, after </ when wrap mode is on.
AppName: pspad.exe AppVer: 4.5.7.2447 ModName: pspad.exe
ModVer: 4.5.7.2447 Offset: 000096b9
Edited 1 time(s). Last edit at 2012-05-11 10:26 by cebe.
