You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2436) English
Posted by: pspad | Date: 2012-01-29 19:52 | IP: IP Logged
Download links (2.7 MB):
pspad.cincura.net
Changes to 4.5.7 (2433)
News
Program settings / System - new option Register as IE HTML viever. Files open from Temporary internet files witout extension will be open with HTML highlighter
Program settings / System - new option Internal browser in IE9 mode
In the menu File/Special added option Delete file history
Search for current word/selection cycles in file same as F3/Shift+F3
PHP highlighter - added keywords trait, insteadof
Ruller font is same as font editor
Into KeyMap was added command DeleteBOL (delete from cursor to begin of the line)
Added new keywords into COBOL highlighter
Code clips - fixed problem when selected text contains char '|'
Exception for Code format and user highlighter
HTML multihighlighter - PHP variable is marked include $ using doubleclick
File change detection was reverted into 4.5.4 version
Code clips - checkbox @K control - fixed default checked state
Posted by: carbonize | Date: 2012-01-30 08:18 | IP: IP Logged
I get this error when trying to save settings. Possibly because of my already existing entry regarding IE9 mode.
Emailed the log to stop cluttering up forum.
Carbonize
Edited 1 time(s). Last edit at 2012-01-30 08:19 by carbonize.
Posted by: carbonize | Date: 2012-01-30 08:24 | IP: IP Logged
Ah OK if you're not running PSPad in admin mode it will error on trying to save.
Carbonize
Posted by: pspad | Date: 2012-01-30 08:28 | IP: IP Logged
carbonize:Ah OK if you're not running PSPad in admin mode it will error on trying to save.
This isn't solution. Admin mode ios necessary for certain (marked) items only. Not for write into HKCU registry.
Posted by: sandrosilveira | Date: 2012-01-30 11:04 | IP: IP Logged
Hi Jan,
I saw a little bug in COBOL Syntax Coloring after update to 2436: the reserved word "VALUE" is colored like a STRING.
Sandro.
Posted by: sandrosilveira | Date: 2012-01-30 11:16 | IP: IP Logged
Another problem more serious with 2436: when I use column selection (Edit Menu / Selection Type / Column selection), CTRL+C and CTRL+V doesn't works.
Sandro.
Edited 1 time(s). Last edit at 2012-01-30 11:16 by sandrosilveira.
Posted by: Anonymous User | Date: 2012-01-30 12:14 | IP: IP Logged
Confirmed. Turning back to previous.
Posted by: pspad | Date: 2012-01-30 12:18 | IP: IP Logged
sandrosilveira:Another problem more serious with 2436: when I use column selection (Edit Menu / Selection Type / Column selection), CTRL+C and CTRL+V doesn't works.Sandro.
I found this bug this morning. I used newest CSV editor snapshot. I will revert too.
Posted by: sandrosilveira | Date: 2012-01-30 13:42 | IP: IP Logged
Another difference in COBOL Syntax Coloring after update to 2436: "NEW", now is recognized like reserved word. We use this in some copyfile's extensions:
COPY SRHPEDWT.CPY.
COPY SRHPDIWF.CPY.
COPY SRH010WF.NEW.
Sandro.
Posted by: pspad | Date: 2012-01-30 13:48 | IP: IP Logged
sandrosilveira:Another difference in COBOL Syntax Coloring after update to 2436: "NEW", now is recognized like reserved word. We use this in some copyfile's extensions:
COPY SRHPEDWT.CPY.
COPY SRHPDIWF.CPY.
COPY SRH010WF.NEW.Sandro.
I am not Cobol programmer. I depends of Cobol users. If somebody sent me information about missing or new keywords, I will add it.
Can you make some summary of cobol highlighter problem and send it at once please?
