You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.7 (2432) English
#1 PSPad unicode 4.5.7 (2432) English
Posted by: pspad | Date: 11/27/2011 16:06 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.6 (2426)
News
Autocomplete - if there is one match only, will be inserted automatically in case you call this function manually
CodeV code explorer - added support for SHR and IMG
FoxPro (Clipper) highlighter - added support for public/static/private declarations
Implemented latest updates of Synedit editor component
Updated JCL library to current version
WordWrap - for TXT files one or more char '.' stays as part of previous word
C# highlighter
fixed unicode support for file names in tabs, taskbar, recent files
3D flip works in Windows 7 or Vista after program start
Paste from clipboard
Code explorer for C - doesn't show functions like bool EXPORTCALL GetDeviceMAC()
Status bar - fixed missong informations after file open
#2 Re: PSPad unicode 4.5.7 (2432) English
Posted by: ok1 | Date: 11/27/2011 23:35 | IP: IP Logged
Is it possible to make the Babylon toolbar "opt in" instead of "opt out".
#3 Re: PSPad unicode 4.5.7 (2432) English
Posted by: pspad | Date: 11/28/2011 05:56 | IP: IP Logged
I don't understand.
#4 Re: PSPad unicode 4.5.7 (2432) English
Posted by: Skulstad | Date: 11/28/2011 08:05 | IP: IP Logged
Hi. What is "3D flip"?
Regards,
Jorn Chr. Skulstad
#5 Re: PSPad unicode 4.5.7 (2432) English
Posted by: human | Date: 11/28/2011 09:21 | IP: IP Logged
opt-in/out: The question was about the installer and to don't install the toolbar by default (the user has to disable it, if he doesn't like it) but only if the user enables it on his own.
3D flip: In Win-Vista and above press [WIN]+[TAB] (instead of [ALT]+[TAB]) - in WinXP usable with additional tools like WinFlip.
human
#6 Re: PSPad unicode 4.5.7 (2432) English
Posted by: Skulstad | Date: 11/28/2011 10:35 | IP: IP Logged
3D flip: ok, I see. Thanks!
Regards,
Jorn Chr. Skulstad
#7 Re: PSPad unicode 4.5.7 (2432) English
Posted by: hamasaki | Date: 11/30/2011 10:39 | IP: IP Logged
Since the upgrade, bak files are being created all over the place. I have it set NOT to create backup files.
#8 Re: PSPad unicode 4.5.7 (2432) English
Posted by: tony72 | Date: 12/01/2011 13:46 | IP: IP Logged
Thanks for the C code explorer fix, great to have that working right again smiling smiley.
#9 Re: PSPad unicode 4.5.7 (2432) English
Posted by: hamasaki | Date: 12/04/2011 01:42 | IP: IP Logged
hamasaki:
Apologies, this isn`t PSPad, but another app.
