You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.6 (2427) English
Posted by: pspad | Date: 2011-11-11 00:05 | IP: IP Logged
New full release is available. Download it from:
www.pspad.com
Please be patient, some mirrors can't be available yet
Posted by: massimobalestra | Date: 2011-11-11 17:01 | IP: IP Logged
Be careful when you install it.
I installed this full version and all my settings and history disappeared.
I tried to restore the settings I was used to (for example I changed a couple of key shortcuts) but closing the editor and restarting my settings were gone again.
I run it as administrator and I was able to save my settings and now everything seems ok. Also my open file history is back.
So be careful, after the installation you have to run it as administrator and restore the settings (maybe there is a way to make a backup before the installation).
I am on windows 7 64 bit.
It is not a big problem, a little work on the installation is worth for using this great editor.
Posted by: pspad | Date: 2011-11-11 17:23 | IP: IP Logged
You have to read what you are clicking.
I guess, you install PSpad as portable version into Program Files.
You can reinstall it with propper settings or run PSPad as administrator (right mouse), then go to Program settings / System
and check multiuser environment
PSpad doesn't delete any settings.
Posted by: PGomersall | Date: 2011-11-14 15:34 | IP: IP Logged
Jan,
FYI - if you use the full installer and de-select languages the installer still copies in the language.ini files. Then in program settings all languages show with ? marks.
Pete
Posted by: pspad | Date: 2011-11-14 15:47 | IP: IP Logged
PGomersall:Jan,
Pete
I can't confirm it. I tested it right now from english installer and in LANG subfolder was only English (can't be removed) and one other language I selected.
Edited 1 time(s). Last edit at 2011-11-14 15:47 by pspad.
Posted by: PGomersall | Date: 2011-11-14 16:18 | IP: IP Logged
Jan - maybe this was because I ran intaller on systems that had the updated developer builds (no language ini's except english though). I also choose a non-default folder name \PSPad rather than "PSPad Editor".
Pete
Posted by: Ilya | Date: 2011-11-15 06:05 | IP: IP Logged
PGomersall:Jan - maybe this was because I ran intaller on systems that had the updated developer builds (no language ini's except english though). I also choose a non-default folder name \PSPad rather than "PSPad Editor".
Pete
I have the same situation.
Posted by: tony72 | Date: 2011-11-25 10:38 | IP: IP Logged
Thanks for the new build, great to see pspad still being developed.
There seems to be a massive bug in the c language syntax however; functions declared with more than one keyword before the function name do not show up in the code explorer. E.g.
unsigned char selftest(){} // won't show up
char selftest(){} // will show up
bool EXPORTCALL GetDeviceMAC(){} // won't show up
bool GetDeviceMAC(){} // will show up
Since these are obviously perfectly legitimate c constructs, that's a pretty serious bug, as it makes the code explorer pretty much useless for c.
This bug has been in several builds, I don't know when it started, but it was definitely not there in 4.5.4.2356 (still my favourite build).
Posted by: pspad | Date: 2011-11-27 12:10 | IP: IP Logged
tony72:Thanks for the new build, great to see pspad still being developed.There seems to be a massive bug in the c language syntax however; functions declared with more than one keyword before the function name do not show up in the code explorer. E.g.
bool GetDeviceMAC(){} // will show upSince these are obviously perfectly legitimate c constructs, that's a pretty serious bug, as it makes the code explorer pretty much useless for c.
Will be fixed in next build
