You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.6 (2426) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.6 (2426) English
Posted by: BudMan | Date: 11/07/2011 17:20 | IP: IP Logged
Skulstad:
Skulstad:
There is an archive file inside the zip, but it has no extension. When I extracted this file, and added a zip extension, it is all ok. May this be the solution?
what do you mean? I checked content of archive and I didn't find any archive inside pspad456b2423.zip without extension
I'm talking about version 2426, not 2423.
I am having a similar problem with WinZip. I have reported the problem to WinZip. They requested the URL and are going to check it out and hopfully report back to me their findings.smiling smiley
#22 Re: PSPad unicode 4.5.6 (2426) English
Posted by: smoon177 | Date: 11/08/2011 09:05 | IP: IP Logged
thanks! i will try it
#23 Re: PSPad unicode 4.5.6 (2426) English
Posted by: smoon177 | Date: 11/08/2011 09:15 | IP: IP Logged
would you mind to show me how to search/replace a multi-line text with in files/folder?
francheu:
smoon177:
I really wish to be able to do it in multi-line.
Use the phreplace extension. You can find it here: www.pspad.com
#24 Re: PSPad unicode 4.5.6 (2426) English
Posted by: ino | Date: 11/08/2011 11:58 | IP: IP Logged
smoon177:
www.pspad.com
1] download the package
2] install it /just copy the content of the zip file to PSPad folder (more details in included phreplace.txt file)/
3] start PSPad
4] new menu item should occur in Menu - Scripts - Multiline Search / Replace or press Ctrl-Alt-F
5] a window with two text fields occur - top is Search text, bellow is Replace text
Note: the default hot key Ctrl-Alt-F can be changed to other suitable hot key (I prefer Ctrl-Alt-H) directly in the vbs script phreplace.vbs
Hope this helps
