You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.6 (2423) English
Posted by: pspad | Date: 2011-10-09 18:17 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.6 (2419)
News
Autocomplete - now is possible to confirm it with TAB key
Open system files funstion opens HOSTS file too
Code explorer for ADA - improoved
User highlighter - added backslash comment possibility (4680 Basic)
Dialogs will show in the screen center if main PSPad window is partially behind the screen
File save dialog for TXT files doesn't contain TXT extension when URL highlight was active
Code explorer for C++ doesn't recognize "interrupt void ..."
Dialogs - the caption wasn't transparent
MS SQL 7 highlighter - AND was moved to keywords
Remove redundant spaces - problem with unicode chars
Highlighter settings / compiler tab - exception when there was no content and button INF was pressed
Edited 1 time(s). Last edit at 2011-10-09 18:17 by pspad.
Posted by: Freeman | Date: 2011-10-11 21:39 | IP: IP Logged
pspad:Dialogs - the caption wasn't transparent
I cannot see changes. #E0C090 is my system-wide clBtnFace but #E0E0E0 is clWindow.
Posted by: pspad | Date: 2011-10-12 06:17 | IP: IP Logged
Now is it ok. Before the text background in the dialog middle had same color as form bellow
Posted by: GoodGuy98 | Date: 2011-10-28 17:36 | IP: IP Logged
I am unable to download this version from the first site due to a 404 error.
The second site does download, but the zip file is shown as corrupt, so I am unable to access the software.
Posted by: pspad | Date: 2011-10-28 17:50 | IP: IP Logged
You are right with first site. But second is OK. I downloaded archive and checked ZIP.
Try to clear your browser cache
