You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2415) English
Posted by: vbr | Date: 03/07/2011 09:56 | IP: IP Logged
I believe, the TC settings were removed (apart from some not intended leftovers)
forum.pspad.com
The mentioned temp files might have been used for testing the monitoring of file changes, but I don't see it in my version (win XPp, PSPad 4.5.5; 2415). Are there still newly created with the recent version?
For color tabs, you have a (curently not translated) option in Highlighters settings: "Barva zalozky" (= Tab colour), which you can asign to distinguish between different file types (based on the highlighter used).
Regards
Posted by: menet | Date: 03/07/2011 19:19 | IP: IP Logged
The TC settings were removed : OK
But the grayed line Editor pro Total Commader is always there in Program settings...>System integration
I have deleted the PSPad_log.txt then opened a file with PSPAD then Edited it and modified with Notepad and saved it. PSPAD warn me that the file was updated, I accept that and then looking in the temp directory the file is recreated (with 2415 version).
> "For color tabs, you have a (curently not translated) option in Highlighters settings: "Barva zalozky" (= Tab colour)"
How do you go to find the Highlighters settings and find "Barva zalozky" ?
EDIT : SORRY I have found it under Settings Menu > Highlighters settings...
But how to have a current tab of a unique different color for all the file types ?
Best regards
Edited 1 time(s). Last edit at 03/07/2011 19:30 by menet.
Posted by: vbr | Date: 03/07/2011 20:12 | IP: IP Logged
ok, Jan will certainly be able to clarify, if needed.
I am not sure about the temporary timestamp, it might be not a leftover from testing but a part of the functionality, which is used only for this kind of concurent access to edited files.
The coloured tabs cannot differentiate the files of the same type using different colours.
The tab colors are based on the rules for highlighter assignment (i.e. file masks).
E.g. html, css, js and php can be distinguished (of course, unless the multihighlighter is used, which can't work this way).
hth,
Posted by: kiendlm | Date: 03/07/2011 21:42 | IP: IP Logged
menet:I don't know if there is a relation but why in Program settings...>System integration, there is a grayed line : Editor pro Total Commader ?
Note that there is a mistake, a "n" is missing in Commander word.![]()
Have you ever looked into the online help for the System integration settings dialog (Click on the question mark in the caption bar and then on any option field in the dialog and the help will appear)? I quote:
PSPad Help File:Editor for Total CommanderSets PSPad as default editor for Total Commander. Note: If TotalCommander is running, this option is disabled! You must have TotalCommander shareware installed for this option to function.
Quotation end.
In other words, this option has been intendedly left in the settings dialog, and it is actually working. Close the TotalCommander before opening the settings dialog, and you will be able to change this option.
The typos you have noticed are in the translation files, not in the EXE file, so you can correct them by yourself if they bother you.
Regards
Posted by: hamasaki | Date: 03/08/2011 17:54 | IP: IP Logged
pspad:hamasaki:In CSS files, double clicking hex codes values also highlights the # part of the value. Before it only highlighted the number as it still does with other files.This a bug or something I`ve missed in the settings?
h
It was made by user wish. It's something you can't live with?
It was described in build changes list.
Ah yes I see that now, sorry. Can it be enabled/disabled in settings? Its very annoying for me as I`ve been used to it without for so long.
Posted by: menet | Date: 03/08/2011 20:15 | IP: IP Logged
kiendlm:Have you ever looked into the online help for the System integration settings dialog (Click on the question mark in the caption bar and then on any option field in the dialog and the help will appear)?
Thanks for the information, sorry to have not looked in the help before.
I use already PSPAD like default editor in Total Commander and I have set it in TC. The option in PSPAD is not really usefull because it can't be set with TC running and for me it is always the case.
kiendlm:The typos you have noticed are in the translation files, not in the EXE file, so you can correct them by yourself if they bother you.
You are not right. The typo is inside the PSPAD.exe file.
And inside the translation files, the 2 lines for Total Commander were deleted (in English, French and other languages) since few beta releases. I have made a question about that just before.
Like the translation is deleted, does the option will desapear from PSPAD options ?
And about the PSPad_log.txt file under temp temporary directory, will it be corrected ?
Regards.
Posted by: pspad | Date: 03/09/2011 05:12 | IP: IP Logged
In my opinion this discussion is obsolete.
The option will be removed - I forgot to remove it.
Same as I forgot to remove timestamp logging.
Posted by: tionescu | Date: 03/09/2011 14:36 | IP: IP Logged
Is there a fix / workaround for the following issue?
in the Code Explorer in case of a C++ (.cpp) file the constructor and destructor names does not appear with entire name but only the final letter.
For example,
CTsmVssWriterThread::CTsmVssWriterThread() appears in the Code Explorer as "d()"
CTsmVssWriterThread::~CTsmVssWriterThread() appears as "d()"
NOTE: i am using latest dev build 2415 that i copied over the PsPad directory.
Posted by: molinarm | Date: 03/09/2011 17:32 | IP: IP Logged
Since beta 2411, I am observing the following problem with C/C++ Code Explorer.
The Function List now displays, for each function, only the last character of the name.
In beta 2405, it displayed the whole name.
The problem seems to be not related to the file size or complexity: I observed it with a little file (2K), with just one function inside.
Anyway, it seems to be so systematic that I wonder whether there may be something wrong in my configuration. I tried to delete the .ini file in PSPad directory and re-launch the application, this took away all my configurations, but the problem with Code Explorer is still present.
Any ideas/suggestions?
Mario
Posted by: PGomersall | Date: 03/10/2011 16:47 | IP: IP Logged
Jan,
I have found a possible issue with the close\minimize to tray icon feature.
You open file A in folder B. You then close file A and "close" PSPad to tray icon - PSPad still has handle on folder B - you cannot delete folder B until you exit PSPad.
I hope this is not by design and that there is a work around?
Pete
